iceguy4
Can we assume you have thoroughly cleaned the unit? It seems your problem started when you introduced a dirty pellet. does the flame look "vigorous"? you say"Instead the feed falters" explain...does it get slower? Did you putz with the feed rate? Feed rate can be adjusted (in spite of what some members say) to compensate for pellet quality. Flame lazy...more then likely an air leak...check with cigarette smoke around doors ect. any codes?We are having some problems with our Hydroflex 60. This is the first season that we have used our Hydroflex 60 and up until about a week ago we were pretty pleased with its performance. Since then the unit has not been able to provide the output needed to bring our home up to heat and maintain the temperature despite the temperature in the 30's and low 40's. The last load of pellets (Energex) were a major step down from the Okanagan pellets we had used previously - creating a lot of ash noticed during cleanings.
The unit starts up and appears to be running normally, but when put under a single zone load the boiler temps hover in the 140-150 degree area (min setting = 160, max =180) eventually falling to 140 when the oil fired boiler comes on to boost temps and shuts down after it has done its job. The pellet circulator continues to work and temps fall back to the 140-150 level and eventually needs another boost from the oil burner. Even though there is a demand for more heat the pellet feed does not respond to the demand by supplying more pellets to the firepot. Instead the feed falters - it does come on, but not enough for a high sustained burn in an attempt to meet the btu demand.
I suspect that the temp sensor may be gunked up or has outright failed. Has anyone else had a problem like this? Our latest supply of pellets are Cubex - because of the existing problem it's difficult to judge their performance.
Thanks, Will
Hence manual operation.
