Great now would love to know how It burns, if you like on the other thread regency cs2600 review (its the same stove) you can post how it's burning there it would help a lot of people that have this stove.
I readjusted the restriction plate to full open, so my burn time didn't improve any, but the heat output improved vastly. Readjusted plate this AM to about half blocked off and just started a fire so I'll give an update later. And I used the top down start method with a fire starter on large splits...what a game changer.
What type of burn times are you getting? That's how my glass gets in the fall and spring when I burn in the winter just some black in the corners. What area do you live in, what are your outside temps and do you know the moisture in your wood.
Filled it up about 430 and at 1 am still had life and at 550 degrees with the load in picture above. 4 large pieces and a small one on the side. Would have went an hour or more longer. Good smoldering logs were left that broke up into large coals.
Had to go to bed so added wood.
Wood has been split for 3 years and is dry maple
Yesterday was mid 30s into the low 20s overnight with light snow. Mason Dixon line area.
