It's a lot but, you want a lot. Probably $25,000 in matterials. I'd try to get another estimate to compaire to if possable.
Might be better to get different house.
Definitely alot of money. But for what you are getting it doesn't seem like alot. Can you use your existing heat emitters instead of doing 4 floors of staple up.
That would really cut down on the labor and materials. Also if the wood will be your primary heat source again can you use your existing boiler for back up since it probably wont get much use.
I spent almost $17,000.00 for my system. The unit was $9,000.00 and the rest went into building a boiler room,(which was my cost of materials and my labor) and paying my plumber for materials and labor. I used my existing boiler and heat emitters.I would love to do staple up but its labor intense.
As far as the price listing here, I personally don't see a problem unless you are giving out the installers name and address. But I also don't really know all the rules.
Maybe take it slow and do it in phases. So it's not one big bang.
Neil,
You can go online at places like PexSupply and price out each of those smaller plumbing parts you listed. Tarm Biomass would give you the cost on the Froling and shipping. A propane boiler shouldn't be all that expensive. Menard's site has all the chimney parts and prices. Find the prices online for everything else you need and add it up yourself. Look for alternatives to the staple up radiant. I bet you could cut the heck out of the $26,618 and labor cost figures. If I thought my installation was going over $20,000 total, it wouldn't be happening.
If I had anything near your budget and your situation I'd find a way to fit in the Garn (because it has its own storage and doesn't need a chimney) and estimate pex instead of copper pipe for panel rads instead of staple up, and price a standard boiler. There is a wide variance in boiler and furnace prices. I can't believe you couldn't come in under $30,000 even with labor.
Hello Neil,
With the big numbers being discussed here I cant help but think there is a better way to solve this comfort/efficiency game.
It seems you love your house and plan on it being your "last" house with this kind of investment. If this is the case I would strongly consider a few things:
Get a blower door test done( a few hundred $'s) to know what kind of air leakage your dealing with.
Do you foresee needing new siding and window upgrades at some point? If so, this could be a great time to add a lot of R value to your wall, add a continuous air barrier,
lower your heat load and increase comfort all at the same time.
It sound like your south facing glass is typical passive solar of the 70's and may not be helping you all that much. There are important ratios between % of south facing glass to floor area, amount of thermal mass that the sun actually "sees", solar heat gain of the glass itself (SHGC), quality of the building envelope, etc.
Properly designed south facing glass should gain more energy than it losses but is not as easy as just loading up a wall with lost of glass.
Obviously I am in no position to say if this is the best approach for your situation, but while your getting crazy expensive quotes on heating systems you might as well get a crazy expensive quote on a deep energy retrofit from someone who knows air barriers, super insulation retrofits, heat recovery ventilation, passive solar design, etc.
I recommend spending some time here:
http://www.greenbuildingadvisor.com/
A gasser+storage may yet be a good option, but I think this too big of an investment to not consider your building envelope first and foremost.
Good luck,
Noah
A job as big of yours would be quite an undertaking. Maybe you could do some of it and hire the rest.
Hi Henfruit,Neil,Based on your heat load you only want to be burning twice a day on the coldest of days.I would have a minimum of 1000 gallons of storage.I think you have spoken to Mark at ahona about your needs?
It's all just thermodynamics. Storage can be "too big" if it's poorly insulated. I have 1k gallons.. and I would love 4! I wouldn't mind that it would take me a couple of days of wide open burning to get it up to temp.. cause you'd have a fire every couple of days in the middle of winter.Hi Henfruit,
Yes, I have spoken with Mark and I was going to go with the 1000 gallon storage from ahona but the comment from tarm saying I shouldn't have more than 800 gallons has me concerned. I wouldn't think the froling would have any trouble heating a 1000 gallons easily, would it?
Thanks,
Neil
I heat my 1500 gallons without any problem with my Froling. One fire a day was sufficient in the winter. When we get a cold winter, I will really get to see how my system works. I love the 1500 gallon storage- I just went 9 days between fires for my DHW. In the summer, I do not want to have to worry about burning every couple of days.
That depends on if you can keep it from mixing.I'm thinking that with well insulated tanks and good stratification, extra gallons won't hurt much. You wouldn't necessarily have to heat all the water fully - as long as the hot water is at the top, and the loads are taken off the top, extra cooler water on the bottom of storage won't affect loading/operation?
