Hello,
Just got my second estimate back for a geothermal instal and it was over a 100K as well.
WOW!
why insane quotes
did I see for 3000 sq ft home?
Did any suggest a 3-ton system with a 5-ton loop for covering ALL cooling and a couple air zones and ALL 100% INSTANT HotWater Heating by temp programming? or a 3,1.2ton 3-staging HW Prioritym that can ALSO heat In-Floor and be backed up by the smallest wood burner...?
(pictorials: geopros.org)
Is the closed loop drilling 100/ft there?
In very hard to use parts of Ohio:
drilling and pumps and gt system for
www.Hydro-Temp.com Priority HW all bells, 3 staging, 75% less costly than oil, 60% less than straight electric, and 40-45% less than even
www.IBCboiler,com (20-115 variable 20-115k btuh)...
@ 4-ton for 3000 sq ft forced air average insulated: HIGHEST retrofitting @ ~ 24,000 less 30% break tax credit and 600 uty rebate... ~ nets out after saving 1600 (-1900 usually, all HW and HVAC ~ 8000 kwh/ annually...
first year at under ~ $ 14,000 with substantially equal operation in sealed ducting and proper return air system, ~ 7 years ROI at worst...
100,ooo was for 4 units,12000 sqft/// half new ducting and radiant floor 3100 sqft.
2009:
on open well of 135 gpm (point.2 PPM iron...)
using ~ 24- 28 gpm at peak -10 below zero, 16 gpm peak summer--- watering the lawn, keeping a pool of fresh water flow at 88 degrees for fun in the summer usage!
radiant costs contractors here now ~ $11/sqft if 1000 sqft hooked to some source with pumps and a controller, or over 1000 sqft for only a little less to ~ 4000 sqft, comes down a bit.
It is recommended only in floors above basement, as forced-air ceiling registers can be directed straight down over slab flooring/ basements/ well insulated, to "create" a floor-radiant warm feet effect, substantially acceptable to ALL WHO LET ME adjust the registers.
-since 1986, found registers needed "bending" in ceilings, and cooling takes care of itself...
