You don't want to knowWho’s going to haul ten cords of wood up to the house and load two stoves, if I’m in jail?
True we often see less sun than say Boston, though there are parts of the state here that are sunnier than others. Where we live we get half the rainfall that Seattle (and NYC) gets. The same happens in the rain shadow of the Olympics.Winters are mud, rain, and darkness for 9 months.
The wife’s new boyfriend! The same guy that will appreciate the survivor’s benefit of my pension that I’m leaving for my wife!
3-4 cords annually is enough for 75% of the registered users here.
You don't want to know![]()
In Alaska! What are you heating an igloo?
Alaskan homes are generally super insulated. Also, like me, he never claimed he was actually in that 75% population.
Or that any of those 75% actually provide 100% of their heat with wood.
Nobody's mentioned this yet, so I will. Wood heat is ... not fast. You can't just flip a switch, ignore it, and have the house warm up by 7 degrees. There's stove loading, monitoring it until it gets rolling, closing down the air, then waiting for that glorious heat to circulate. Wood heat becomes something of a lifestyle choice. Just something to consider.When she comes home it gets jacked up to 70 degrees
Depends on the house. I can’t heat my place near Philadelphia entirely with 10 cords, but many do it on less. There are several past and present members here, with no central heating system, who entirely heat their house on 3 -4 cords per year. One of particular note lived in Michigan. Their houses may be smaller, and better insulated, than yours or mine.
There is no way in hell heating only with wood you're only burning 3-4 cords unless you're in Kialua
How does backup heat effect the amount of wood you burn if you don't use it? I work for hundreds of people a year in a similar climate 8 to 10 cords is much more than average especially with a modern stove.So far most have back up heat and keep temps around 70, me I want it above 76, burn from late Sept to May no backup 8-10 cords.
I know Flemington well, used to pass thru it daily for work. You run pretty close to 1000 HDD/month in Dec-March, meaning 33 HDD/day, meaning the average temperature is pretty darn close to 32F. If you increase your thermostat from 70F to 76F, that's a heat rise increase of 16%, so your fuel usage should be approximately 16% higher than someone keeping their house close to 70F in your climate.So far most have back up heat and keep temps around 70, me I want it above 76, burn from late Sept to May no backup 8-10 cords.
