Ok, took off the air cleaner...looked very good.
Sprayed some carb cleaner into the intake, set to choke, and pulled cord.
Runs at full choke (I'm guessing as its using the carb cleaner as fuel)
If I take off choke, engine dies. Going back out...check the bowl next?
, what would be the diagnosis of when I had it running at first, but it would only run on full choke? (Seems like full choke means no/less air going into the carb/engine? I had it running for like 3-4 minutes on full choke, and then would die out if I moved the choke even the smallist amount to the left.
