Froling install question
Dogwood, it’s really hard for me to say how many hours he spent actually installing the system. The boiler/tanks were dropped off in mid November and the first fire wasn’t till mid January. Then it was up and down a couple times to fix leaks. Work was mostly done in small increments with a couple full days thrown in. If I had to guess I would say 60-80 hours were spent on site installing. This spring I have spent numerous hours fixing more leaks that developed in all the brass to black iron threaded connections.
At first I spent a bit of time looking at the electronic readouts. You know, looking at oxygen levels, stack temps and whatnot during a burn. While it is interesting, after a couple weeks I pretty much stopped. The only thing I changed a bit was the temp the tanks need to be before the boiler shuts down. I basically bumped it up to the max, which is 90 Celsius (all readouts display in centigrade).
I’m burning 90% dry mixed hardwood. I burned a bit of softwood and other than the quicker burn I had no problems. Just open the door at any time and throw more in as needed. This winter I plan on burning a bit more soft wood since I’ve been taking down some big old hemlocks.
I assume you are asking about the amount of smoke I get from the chimney. This is really minimal. It’s very hard to see any at all most of the time. It also has a different smell as well. It’s almost like wood or nuts or something being toasted. It’s hard to describe but it’s totally different than typical wood smoke.
Last night I took a look at model numbers of the pumps that were installed. On the return side of the boiler there is a Wilo #4095807. The boiler turns on this pump when aprox 65 degrees is hit. The other 2 pumps are 3 speed Wilo #4090765. These are on either side of the Caleffi hydraulic separator and locations can be seen in the pictures in the previous post.
I plan to take some pics tonight but with a 4 month old baby in the house who knows how that will go……
Jon
Jon, if you care to come to Virginia my wife will babysit your young one. Are those Wilo-Stratos circ pumps you have ECM types. I'd really have to be even more jealous then. I'm beginning my eleven day vacation tonight and will attempt to do the calculating, and likely miscalculating, of my system components, utlizing the valuable input you all have sent on this thread. I really do appreciate your time and input. All the regulars who submit to this forum are real celebrities to me, like Brittany Spears and Lindsay Lohan to a lot of others. Maybe I should start collecting replies like autographs. Imagine getting a a reply from the illustrious Mr. Nofossil, Joe Brownian, or even the elusive "Hot Rod" Rohr, with the ultimate goal of a Craig Issod, or even a John Sieganthaler post. Who needs Brad and Angelina? These folks and all you regular contributors are the ones who've got it going on. You all should be getting chased around by paparazzi. I think I'm having too much fun just starting a vacation. Jon and Jim, thanks for your replies. Looking forward to those photos.
Mike
Storage tanks connection to water supply. The plastic tube is for my freezer ice maker. Chimney is to the left. Far right tank is behind wall.
(broken link removed)
Boiler return and over-heat loop
Other end of over-heat loop and storage side of Caleffi hydraulic separator
Termovar return temp protection and my dumb beagle looking for a rabbit
Bad pictures of the front
If anyone wants pictures of anything specific let me know.
Jon
Can I have a closeup of the first red X? :cheese:
Pics aren't showing up for me...
I just tried on a couple different machines here at work and they show up fine. They are hosted on Picasa.
Can anyone else see them?
All that I see are photo file names, such as "tank_fill.jpg tank_fill_2.jpg" but there's not an associated URL as to where they are
I've tried to post them like this:
with the img tags
and now without the img tags and just the URL.
Is there some trick other than right clicking on the picture, selecting copy image location, and the copying it into the forum?
These are some other pics I meant to post the first time around:
Tie in to backup boilier:
Supply and return:
Primary and secondary air supply control motors:
Wiring (black magic to me):
Boiler Display:
I can't see the pictures....all I can see are dollar signs.
Looks sweet.....
Thanks a lot.
Stage 2 of this project is getting rolling this weekend. 360 extruded aluminum plates and 2000' of 3/8" pex are being delivered today. Hopefully I don't get in too big of a mess installing it all.
Good luck with your new project Jon, and thanks for the additional photos. I will study them. I'm hoping my installation will look even a fraction as impressive as yours. Let us know how your new project turns out.
Mike
