KC Matt
Burning Hunk
OK, this is the schematic. Keep in mind I'm no engineer and this is the first use of this software so this may not be technically correct, but it's accurate. For one thing there is no option to show how the Johnson Control box actually works, but it's a double throw single pole switch so that's what I used. Also, there is no reason to ever buy a 419 box because the 421 is much improved. And there is no reason to buy a controller powered by 12VDC but that's what the 419 is This was a learning process for sure.
Over the last year I've spent dozens of hours watching this furnace cycle, tweaking the settings over and over. These are the settings that worked best:
Damper control:
Set point adjusted for heat demand
Differential 2*F
ASD no
OFS 0
Sensor failure 0 (Closed)
Blower on/off controller
On 97*F
Off 83*F
Sensor fault 1 (blower on)
ASD 2 minutes
High/low blower speed controller
on 91(low speed)
off 93 (high speed)
Sensor failure 0 (high speed)
Model A421 ABC-02
Damper control:
Differential 2*F
ASD no
OFS 0
On 97*F
Off 83*F
ASD 2 minutes
on 91(low speed)
off 93 (high speed)
Model A421 ABC-02
