KC Matt
Burning Hunk
Why invest in modifications for the furnace, when the attic needs insulated? We have a Caddy, but it's the same firebox. There's no way I could burn thru a full load in two hours, especially hedge or locust. Ideally, you should still be able to heat your home off the coalbed if it remains hot. It was 11 degrees last night and it was 71 in the house after 10 hours. Probably 4 or 5 of those hours were strictly coals and they maintained heat for some time.
I have another project that requires attic access and having mountains of insulation would make that job difficult. After I get to that project insulation is next. Good to hear yours works so well. I obviously need to tweak something with mine.
This stove seems to like Pine as well or better than good hardwoods. It doesn't do too well on hot coals and that's what the hardwoods make. Now good dry Pine will make a rip roaring fire that will heat the house up for sure...you need some insulation to hold the heat for more than 2 hours though.
Damper open after the fire is established is just wasting heat up the chimney...you need to use that manometer and set things up correctly.
A couple loads like that and all you'll have is a full load of hot coals...these things need 8 hours or so to burn a load off...hard to do it in less with hardwoods.
Heatmax is the same furnace with just different trim...you mean the Heatpro?
Absolutely not. That is what SBI claims cracks these things...and a super waste of heat up the chimney.
Have you set your static pressure?
Sounds like you would benefit big time from a temp controller and a blower speed controller (true variable speed, not multi speed like you have now)....my blower runs 98% of the time with little cycling now that I have variable speed...and no, it doesn't blow cold air at the end of the burn.
I'm with ya man, I was so close to throwing mine out in the scrap heap...once multiple issues were sorted out and the temp controller and speed controller were installed it is a whole different machine.
I meant the heatpro but it's good to hear this furnace can do much better than I'm seeing now. Static pressure, no. Where did you buy your variable speed setup and how much did it run? As it is, I don't know this furnace would benefit much from variable speed. It really wants to run on speed 1.
The house doesn't lose a lot of heat in 2 hours, I must have worded that wrong. What is becoming clear is that the Tundra is not good at increasing temps, but will maintain them.
No, not at all.
One thing that comes to mind is for people to not get too hung up on maintaining an exact temp in the house like with fossil fuel heaters. Wood heat fluctuates...some systems more than others.
Also, so what if you have to supplement a bit at 5 AM on a REALLY cold night...we don't really get that many of those kind of nights (days) in a years time, so if your main furnace kicks on for a bit 1 or 2 times per day, big deal...you are still cutting down on you usual heat bill by big margins most likely.
Tundra (and any EPA style wood heater) works best with the intake damper closed once the firebox is up to working temperatures. If your thermostat is calling for heat all the time, holding the damper open non-stop, you are wasting heat and running the bag of your heater for no reason.
I'm a lot happier with the Tundra when I'm just maintaining the temperature in the house than I am coming home to a cold house and using Tundra to try to raise the temp back up more than a couple or 3 degrees or so (at my house YMMV) They just don't have the firepower needed to raise temps a lot unless you are willing to do it over an extended period of time. They work much better maintaining a given acceptable temp range.
Set your heater up per factory specs (all of them)
Use DRY wood.
Have realistic expectations (I have to keep myself in check sometimes too)
Carry on...![]()
I will go through the manual again and see what I missed. The furnaces are sharing ductwork and there is no way to put a backflow damper on the gas furnace. The supply side on the wood furnace would be easy, but then wouldn't it be cycling the warm air straight through the gas furnace? In order to prevent that I've replaced the gas furnace filter with a block off plate and there is another for the Tundra for when the gas furnace is on. Is there a better way to do that without being able to damper the gas furnace?
