Still best would be to run actual returns to the space your heating then maybe steal from the front. A complete install always works best. But if that is not possible jrhawk9's way would be 2nd.
I once upon a time built a re burning barrel stove. I made intake tubes from galvanized steel tubes. worked well.Hey All,
my secondary burn tubes are looking ROUGH! after three years of burning they are warped and dont really perform as the should. i suspect some of the air holes are clogged with debris or corrosion. i was planning on replacing them , they (drolet) sell the main 3 for $60, and the front tube (singular) for $60 bucks also...so $120 for 4 tubes. wondering if anyone has any words of wisdom when it comes to the secondary burn tubes. replace all 4 or just the back 3? I didnt locate this topic in the previously threads so im asking now.
thanks!
Once the firebox is up to temp, running "damper open" is bad for efficiency as far as capturing that heat and putting it in the house...sounds like you could benefit from a speed controller on your blower...made a big difference for me. It changes the speed of the blower to try to maintain a temp...the way mine is set up it is running full tilt by 117* duct temp...then slows down as the temps drop, finally shutting off around 93* (it is running at about 60% speed at 93*) then it restarts the blower as soon as the temp creeps back up around 10* (103*) It can be tuned for your setup...I love mine...thinking about putting one on my Drolet 1400i fan tooYou can run the updated model Tundra 1 "Balls Out" which is best for efficiency of heat from wood
I've played with the fan speed on it multiple times. I want a shorter hotter burn than it can achieve as its setup. I come home to too many coals. I messed with these things enough I really feel finding some way to increase the burn of cycle would work well. Im home every 8-10 hrs and on cold days would like the higher heat with shorter burn. Hence a temp controlled method of doing this beyond just main damper. I'm thinking just a low speed blower connected to the bottom intake hole with some tubing. I have messed around with blowing air in their for lighting week coals and works very well.Once the firebox is up to temp, running "damper open" is bad for efficiency as far as capturing that heat and putting it in the house...sounds like you could benefit from a speed controller on your blower...made a big difference for me. It changes the speed of the blower to try to maintain a temp...the way mine is set up it is running full tilt by 117* duct temp...then slows down as the temps drop, finally shutting off around 93* (it is running at about 60% speed at 93*) then it restarts the blower as soon as the temp creeps back up around 10* (103*) It can be tuned for your setup...I love mine...thinking about putting one on my Drolet 1400i fan too![]()
Heck I'll probably just drill out the bottom intake hole a little bit. I did that with a Defender stove and was happy with the results.Once the firebox is up to temp, running "damper open" is bad for efficiency as far as capturing that heat and putting it in the house...sounds like you could benefit from a speed controller on your blower...made a big difference for me. It changes the speed of the blower to try to maintain a temp...the way mine is set up it is running full tilt by 117* duct temp...then slows down as the temps drop, finally shutting off around 93* (it is running at about 60% speed at 93*) then it restarts the blower as soon as the temp creeps back up around 10* (103*) It can be tuned for your setup...I love mine...thinking about putting one on my Drolet 1400i fan too![]()
ehh with Tundra I guess I'd open up the main intake a little rather than the lower intake.Heck I'll probably just drill out the bottom intake hole a little bit. I did that with a Defender stove and was happy with the results.![]()
To be clear too I'm talking about for the last few hours of a burn no when the firebox is up to temp.Once the firebox is up to temp, running "damper open" is bad for efficiency as far as capturing that heat and putting it in the house...sounds like you could benefit from a speed controller on your blower...made a big difference for me. It changes the speed of the blower to try to maintain a temp...the way mine is set up it is running full tilt by 117* duct temp...then slows down as the temps drop, finally shutting off around 93* (it is running at about 60% speed at 93*) then it restarts the blower as soon as the temp creeps back up around 10* (103*) It can be tuned for your setup...I love mine...thinking about putting one on my Drolet 1400i fan too![]()
Yeah I mentioned on second thought adjusting the damper intake back to the larger cut outs would make more sense based on the function of Tundra. Your right. I think I may just try putting a grate in an burning smaller hotter loads closer to the top to achieve hotter 8 -10 hr burns at higher heat rather than 14 hr burns. I think this is what I want and realize it will consume a little more wood but will remain on the proper dialed in setup running with damper closed for most the burn. Its those last few hours of a huge load that just seem worthless no matter how low the fan is set for speed or turn on but if I load to early we of course wind up with a pile of coals half way up the fire box. lol.I'd caution against that. Your particular setup doesn't have gravity flow, which already makes things dangerous during a power outage. Opening up that hole will make it much worse, since that hole is the main driver for combustion rate with the damper closed. And, air flowing through a hole increases a lot for even a slight diameter increase. And, it's not a reversible mod, unless you weld or plug it back up some other way.
I'm not convinced about a fan of a powered air injector to that air hole, but at least that cuts out during an outage, and you can undo it if it doesn't work. I'd start with that.
Besides putting a grate in is the quickest, easiest, most easily reversible modification I will have ever done with this setup. lol.Yeah I mentioned on second thought adjusting the damper intake back to the larger cut outs would make more sense based on the function of Tundra. Your right. I think I may just try putting a grate in an burning smaller hotter loads closer to the top to achieve hotter 8 -10 hr burns at higher heat rather than 14 hr burns. I think this is what I want and realize it will consume a little more wood but will remain on the proper dialed in setup running with damper closed for most the burn. Its those last few hours of a huge load that just seem worthless no matter how low the fan is set for speed or turn on but if I load to early we of course wind up with a pile of coals half way up the fire box. lol.
That is exactly where the speed controller shines the most...the blower stays on low for extended times instead of just a quick blast and then off again for 5-10 minutes. That and the blower can be wired to a higher speed than would otherwise be optimal...then you can take better advantage of the intense heat available at the beginning of a burn.Its those last few hours of a huge load that just seem worthless no matter how low the fan is set for speed
I think the idea, for me anyhow.. is to shorten the load time some basically raise the bottom of the stove putting fire closer to the top and making it a shorter hotter burning load. Same could be done with fire brick. The only hang up I see in this is getting above the air intake hole at the bottom of the firebox. Seeing I use the temp controller and the high limit is set so low, seems likely opening the side intakes a little bit could help me achieve what I want while still maintain a larger load. Now of course this is going backwards from SBI's factory modifications to keep stoves from cracking but basically what they ultimately have done is made it run cooler period. I need to juice it back up a little. lol.Yea I agree. Hate to wait to start another load when it's cold, and hate shoveling out and wasting coals.
One thing I've been doing is using the flat top of the rake to scrape the entire coal/ash mix to the front, then using the tines to push the larger coals to the rear again. This lets the coals continue to burn and give me heat on the next load, and the small coals burn out of the ashes at the front, which I scoop out before reloading. I have very few coals in my ashes this way.
I look forward to hearing your results. Recall that KARB2014 tried that and reported on pages 30, 53, and 54. He seemed to like it. I never knew how he practically scooped out ashes, though. Would love to hear what you think.
sorry the side intakes on the main damper. SBI choked them down a bit thru out their mod process.I think the idea, for me anyhow.. is to shorten the load time some basically raise the bottom of the stove putting fire closer to the top and making it a shorter hotter burning load. Same could be done with fire brick. The only hang up I see in this is getting above the air intake hole at the bottom of the firebox. Seeing I use the temp controller and the high limit is set so low, seems likely opening the side intakes a little bit could help me achieve what I want while still maintain a larger load. Now of course this is going backwards from SBI's factory modifications to keep stoves from cracking but basically what they ultimately have done is made it run cooler period. I need to juice it back up a little. lol.
The Kuuma kinda already has something similar...I'm not sure you would see as much difference as i did just because of the way your machine works.this is the cats a s s. I really would like to try this on mine.
BTW, I checked my furnace room temps this morn, 69* on the wall at the floor...79* on the wall at the ceiling...seems like I need to do some "preheated return air" experiments
