Thats because the stove is in a negative. That pan in the air flow of the unit causes the unit to suck it out and push it into the living space.
Welcome to hearth, @Pinny !
Sure, that's possible, but no worries. The idea of the table of contents is to help, certainly not to suggest the same question can't be asked twice. We look forward to hearing from you.
This is my first year with my own wood furnace! A Drolet Tundra! I have learned quite a bit from you guys already as well as some fires I have been burning. For me the beginner I have found much of the information is very useful to learn about not only the stove its self but all the variables that go with burning wood.The only suggestion I can offer is to maybe bring up in the 1st 5, The ash pan issues on the 1st models. This is a life and death issue with these units and as far as we know SBI has not reached out to the owners of the deadly design flaw. Now they are selling display models that may well be the same death traps as the original. Maybe just a warning in the beginning about the deadly start of the Tundra.
Welcome to hearth, @KC Matt !
I'm fuzzy on the differences between new and old versions of the Tundra I, but look at pages 38, 48, and 50 of this thread, including some serial numbers. Search the link in my signature line for more. I think the assumption around here is that we didn't trust SBI had solved the cracking on any Tundra I. Time will tell for Tundra II.
I don't recall people having trouble with the flue collar. I can try to measure mine when I get home to see if it's the same size as yours. Have you measured your draft?
I'd be willing to bet the replacement one that @Digger79 got from SBI will be just fine...I think the assumption around here is that we didn't trust SBI had solved the cracking on any Tundra I.
The exhaust outlet is 5 7/8" ID
I am still on the original unit that I recently had the cracks welded.I hope so. I got my users confused, I was thinking of @Builderml 's posts on page 38. He got cracking on ser# 1993. I think it was either him or @Digger79 that are on their 2nd Tundra, after their 1st warrantied.
Either way, Builderml's cracked on a serial number later than @KC Matt 's. And, I admit I don't understand if we ever concluded around here we had a strong theory for what caused the cracking, so I'm not able to describe how/if SBI has actually fixed it.
If you cut it they would probably deny a warranty claim because you modified it "and that's why it broke"Do you think it would be worthwhile to use a dremel and cut those welds, or face the odds of cracking and expect a refund?
Like Brenn said i wouldn't give SBI a reason to deny a warranty claim. With that said SBI didn't ask for any pictures of those welds when i filed the claim. They asked for inside firebox and the cracks and an overall install photo. It's really your call to make. Just keep a very close eye on those two lower corners so you can catch the crack at its very early stage. Also don't drill the crack until after warranty is done. Not sure how accurate this is but the right side cracked first for me.Do you think it would be worthwhile to use a dremel and cut those welds, or face the odds of cracking and expect a refund?
Read post # 1714. Hope that helpsPeople mentioned the firebox being welded to the face plate on the old models, and thinner material on an air deflector one one or the other, and looking at the pictures posted and at my stove, I can't tell what they are talking about.
The stove isn't hooked up currently so I haven't measured the draft. This thread is so long and I know there were instructions on how to measure it somewhere. I planned to install a manometer and a thermometer.
I noticed the flue never got above 375 degrees.. and the damper only closed when I manually closed it.
I also installed the adjustable thermodisc and have it set to 100 degrees.. The fans only kicked on a couple times and only ran maybe 10 minutes....
I have High temp insulation blankets that I am installing inside the cabinet this weekend if I have time...
Are the clearance to combustibles met?
