Yeah, kinda, there is no space between them, but definitely two layers. I would guess it is there as a flame shield.That's odd, a false top. There's where alot of heat exchange occurs. That would explain a lack of heat.
Yup, blower amps went up, temp went down. (I have the unit plugged into a Kill-A-Watt monitor)(yeah, I like gadgets and gaugesDid you open your dampers? What does your tie ins look like?
Yup, blower amps went up, temp went down. (I have the unit plugged into a Kill-A-Watt monitor)(yeah, I like gadgets and gauges)
I am using the two side duct holes as recommended, I have two 8" pipes straight up into the main trunk line. I have the Yukon blocked off so the airflow can't back feed.
I have the filter access door off of the Yukon and the filter of the Tundra is facing it, about 3' away. I have checked the air temp of the air down by the floor in the furnace room VS the return air from the duct, 1 or 2 degrees difference. A couple days ago I remember going upstairs and thinking that it was warmer in the basement than upstairsOpen return, or ducted?
Thanks! Happy Thanksgiving to y'all too.Thanks and happy thanksgiving!
I have the filter access door off of the Yukon and the filter of the Tundra is facing it, about 3' away. I have checked the air temp of the air down by the floor in the furnace room VS the return air from the duct, 1 or 2 degrees difference. A couple days ago I remember going upstairs and thinking that it was warmer in the basement than upstairs![]()
With the little wood that I have
Haven't taken the cabinet apart...yet.Did you happen to look at the insulation on the jacket?
There is a bunch of air flow coming out when I remove one of the duct connector block off plates, actually a surprising amount for the fan being on "low". And I didn't hear any flapping or buzzing like I would expect if there was loose insulationIf the insulation gets loose it can block air flow when the fan comes on.
You should post pics of the ridiculous amount of nothing that comes out of a Vaporfire when you clean it, most of these guys have probably never seen anything like it out of a wood burner. I'm gonna post my cleaning pics...you post yours! If you don't want to put them on a Tundra thread then put 'em on a Kuuma thread and then just drop a link here. The only area that I found that had the white powder that you always get was the front 3/4 of the firebox top, above the baffle.After all this talk of dirty heat exchangers and it being 55* out, tonight I cleaned mine.
Because I'm not getting duct temps as high as yours. The temps I stated were 2' above the furnace, I haven't checked duct temps further down the line, or at the registers, I probably should though. I only get temps above 100* while the damper is open, or maybe for a while after the damper closes during the intense part of the secondary burn. Once that is over we are definitely under 100* duct temps right above the furnace. Like I said before, If I had 110-120* duct temps (consistently) I would have no problem heating the place with that, but 90s, even 80s (remember, I have the old style fan switch in the back) during the end of the burn cycle are barely cuttin it, and the weather is pretty mild, so I don't have a lot of faith that this is gonna work out when the temps drop. I guess I need to move the fan switch, see if that makes any real difference, one thing at a time though.
Where? The holes from the firebox or the clean out door? The holes from the firebox are probably 4.5" x 3". The side HEs are about 4.5" diameter and the center one is 6".That HE opening seems/looks like 6X6, is this true? If so, that is the issue and no fix for that. Also explains a lot.
Thanks for the cleaning info builder, 4 cups doesn't sound too bad to me, but I dunno?also does not have access to the fan speed control. Guess I do need to make an access panel to get in there
I had a few choice words for that smart move on my part.
I'm 90 minutes into a burn, full load mostly box elder and a couple small elm splits.
I just lost enough offgassing to maintain the secondaries,
So what exactly are you pointing out as the issue here? I'm cornfused(er)
You're close. 2 vertical rectangular columns (pretty short) that connect the 2 smaller side HEs to the firebox. The smoke/gasses travels forward to the cleanout box seen in my last pic, where they then converge together into the center HE, then out the back into the stovepipeMy bad buddy. Reread what you wrote, I see there are 3 openings not one. So what does the he look like? I am envisioning 3 square vertical columns in the rear that then send 3 round cylinders to the front mating into 1 box.
How long was your over all burn time on that load?
