Interesting findings here, I fired the Tundra tonight for the first time since putting my "restrictor plate" on the intake holes...wow, what a difference! It is in the mid 30s here right now, so this is probably the coldest temp I have fired up at since I have installed this thing.2nd fire of the year. I figured I get the stove pipe up to 625 f before shutting the damper. Problem is I could only get it up to around 500 f. It was a small load. Maybe this is why?I did get good ssecondary burn for about 10 min. tricky tricky
Even with the cooler temps it seems to take a lil longer to get up to my programmed high limit temp (500* right now) and it seemed to be almost stalled out at 500, it would have ripped right past that temp to bounce off the 625* ceiling before. And the firebox is not nearly the turbulent, raging inferno that it was before when the damper was open, so I'd say mission accomplished for me since I was trying to soften the "drop the hammer" effect of the damper opening.
I also noticed that my draft reading stays higher when the damper is open now, which makes sense if you think bout it. The draft would go from -.06", down to -.04" with the damper open, (at first) now it only drops to -.05"
We'll see how this all pans out long term...so far I am liking the mods I have done. The "light it and walk away" capability that comes with the temp controller is pretty cool IMO ("two thumbs up" smiley inserted here)(if hearth had one)
