The big SUVs are not their best sellers globally. The Corolla, Rav4, and Camry are.Agreed. Toyota makes a lot of big SUVs and pickups. They're best sellers. And some Prii.
This is just like if BK made a bunch of smoke dragons, and a few very fancy cats with super low emissions, and then greenwashed that they were good guys because some percentage of their products were these nifty cats.
Hmm, that is until they did.The reality is that some car makers are trying to pay off politicians, and to spread misinformation to prevent climate progress or legislation. And some other makers are not. Toyota is the former.
I'm saying that we are at BEV/ICE cost parity for small sedans and hatches, but not trucks or SUVs. And if you drive one of those, and live in an area with good DCFC and have an L2 at your house... the EV revolution has arrived.It’s not cost parity. Depending on options, half ton trucks are ranging from the 40s to over 100k.
2 things are keeping EVs from the mainstream.
Products that don’t meet the needs of consumers and slow/lack of charging spots.
The charging spots is probably the biggest issue. It’s getting better, but not everybody lives in an urban or suburban environment and it takes longer to charge. When every gas station has a charger and it only takes 5 minutes to recharge an empty battery to full there won’t be a reason not to buy it.
Eliminate the reason for range anxiety.
That is the case in our town. There are a smattering of Rivian's, but a lot of Teslas, ID4s, Priuses, Rav4 Primes and recently what seems like a notable increase in Leafs. I think this is because most people charge at home, for local stuff the short range is not a problem, and they are cheap on the used market. I suspect that many of these folks have a 2nd car or use public transport to get into the city, though the Leaf round trip range can cover that for some.I'm saying that we are at BEV/ICE cost parity for small sedans and hatches, but not trucks or SUVs. And if you drive one of those, and live in an area with good DCFC and have an L2 at your house... the EV revolution has arrived.
It's not just the US that is pushing GM/Ford/Stetlantis. They are global companies and the international market is pushing them to switch to EVs soon. America is a niche market. It often defies commonsense. For years the big 3s have been pushing big vehicles for image and "safety" due to size. They dressed up trucks as early SUVs to avoid some EPA requirements and because the profit margin was much higher. This lead to a competitive spiral to bigger and more macho vehicles until housewives got saddled parking the Queen Mary at the grocery store. The market mentality of supersizing and bigger is better is a hard one to shake even as the average family size in the country is on the decline.
We don't need cars that go 0-60 in 3 seconds. In fact, they can be dangerous to the inexperienced driver. Most 2 child families don't need more than a 5 passenger vehicle. A 9 passenger Suburban or minivan is often an outlying case but America is built around the car so they keep getting pimped bigger, heavier, and faster to the point where average safety guardrails and barriers can no longer contain them when they are out of control.
Weird. I wonder what the architecture is? Existing DCFC units are 400V or 800V nominal, running at 150 kW or 350 kW respectively. In both systems are current limited at about 400 amps.![]()
NIO's first 900V EV drive system rolls out with 150 mile fast charge in 5 min(U)
NIO’s 900V drive system rolled off the production line Wednesday, according to the Chinese EV maker. NIO’s (NIO) “Thunder” 900V...electrek.co
Pretty impressive charge time. I'm assuming it would have to be from a level three charger ?
Most EVs use a 400V DC onboard drive architecture, and the 800V models break the bank into two parts which run in parallel for driving the car (at 400V) or in series for charge (at 800V). Moreover, 400V (or 800V) is a maximum rating, EV batteries run more like 350V when fully charged, to allow for some swing with SOC and ohmic losses in the cabling.
Keep in mind that the 350 kW nominal 800V standard, say 300 kW actual, for 20 minutes would deliver 100 kWh or 250 miles of highway range. So a 20 minute stop every 3+ hours of drive time is NBD. 800V EVs today, however, can't quite keep up with this DCFC standard, but that can be improved with newer battery chemistry.
The issue is cables to deliver 400A need to be liquid cooled and going higher makes them really fat and unwieldy. So if you want the power to go much higher than 350 kW, you will need to up the voltage. But the current 350 kW and 800V standard seems pretty adequate for light vehicles.
My Bolt DCFCs at 400V nominal, and 55 kW peak, and 40 kW or so on average. Or 1/8th as fast as spec'd by the current 350 kW units.![]()
That's actually an interesting thought I never considered, but should have dealing with welding cables, that's big amperage to put through a hand manipulated cable. 400 amps is outside of standard AWG sizes if it's not cooled by artificial means.
I wonder where the voltage limit is by code for chargers? 1000volts?
That's why utility solar systems max voltage was increased to 1500 volts from 1000volts. 50% more power can now travel down the same conductor, which saves a lot of copper on a large solar array.
The normal voltage limit is 600 volts for conventional insulation. Anything bigger than that is considered high voltage and requires special design and larger clearances. The electrical code was modified about 10 years ago to allow 1000 volts in solar farms with limited access. Those plants need to buy specially rated gear and wiring . When voltages get over 600 the potential for arc flashes is much higher and harder to extinguish with conventional insulation.That's actually an interesting thought I never considered, but should have dealing with welding cables, that's big amperage to put through a hand manipulated cable. 400 amps is outside of standard AWG sizes if it's not cooled by artificial means.
Is there any difference between AC and DC for these definitions of high voltage?The normal voltage limit is 600 volts for conventional insulation. Anything bigger than that is considered high voltage and requires special design and larger clearances. The electrical code was modified about 10 years ago to allow 1000 volts in solar farms with limited access. Those plants need to buy specially rated gear and wiring . When voltages get over 600 the potential for arc flashes is much higher and harder to extinguish. with conventional insulation.
When I used to install large variable speed motors in a paper mill, it was less expensive to install a 2300 volt to 460 volt transformer in front of a 460 volt variable speed drive and run very large conductors or even multiple conductors to a 460 volt motor than to buy a 2300 volt Variable Speed Drive. The 2300 volt drives were huge and took up a lot of space and cooling capacity in a motor control room where pace was always tight. The internal clearances for the higher voltages are much higher and the components are much more expensive.
Most industrial plants use 460/480 volt gear. I have run into eastern Canadian and even some US mills that run a higher voltage, 575 volts) that stays under the 600 volt limit. That means the amount of copper or aluminum in the cables and gear can be little bit less due to lower amperage than in a 460 volt system.
Yeah, all the existing DCFCs in N America have liquid cooled cables (at least the ones 150 kW and above, I don't know about older 50 kW units). This is a maintenance issue, because you need a pump, fluid, a heat exchanger and sensors to confirm that the flow is occurring.
If anything goes wrong with that fluid system, the DCFC will derate to a much lower current, rather than shut down completely. Typically just 25 kW at EA stations. This is waaaay better than 0 kW if you are low on electrons in a snowstorm, but damned frustrating if you were expecting 125 or 250 kW.
These derated units will not post an error code on the display or in the app, so you will encounter them. Happened to me a couple times. And then if you know what's going on, you just move to a different unit and you're fine. If you don't, you sit there and rant and rave about how terrible DCFCs are and how you should never have bought an EV and post it on social media.![]()
I do not think so. Then again when selecting cables there are all sorts of special armoring and insulation classes. Exposed PV wire had to be USE2.Is there any difference between AC and DC for these definitions of high voltage?
It could have been bumped up in the US as most of my big PV background is 10 years old.That's interesting Canadian Electrical Code allows for solar installs up to 1500 volts at utility facilities. 600 volt is the limit for residential applications, really 480 volt because our code requires a 125% multiplier be added to the max OC voltage of the panels.
480 volt and 600 volt are pretty much equal around here in use. I've seen motors up to 4160 volt at compressor stations, usually driving 6 throw natural gas compressors. These were somewhere in the 4000hp range. But they used soft starts and not VFD's. There was no reason to make the motors variable speed, when volume and pressure were just as easily controlled by valves on the piping. Although these are become very uncommon, due to electrical grid restrictions (and power costs) most of the motors are now reciprocating natural gas engines.
Arcing (when insulation is penetrated) is easier with DC. Not sure if the efficacy of insulation differs as a result of this (i.e. whether different insulation standards apply to DC than AC).I do not think so. Then again when selecting cables there are all sorts of special armoring and insulation classes. Exposed PV wire had to be USE2.
