Hello there fellow americans
First I would like to say English isn't my mothertongue so please forgive the spelling- and grammatical mistakes
Second, congratulations with this superb site you have here, I used it a lot the previous few months and read through a lot of threads (also the older ones) and articles I can find. It's this site that concinced me to buy the stove which heats our small, cosy house we rent here. There is no insulation, but that stove keeps everything warm ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
We here in Belgium and Europe don't have any EPA-like-rools for wood stoves. It surprised me what kind of stoves one can by here, the kind that would never pass the least strict EPA-rules. There are a lot of inexpensive, steel (not cast iron I mean) stoves where the air-inlet is beneath the fire, where there are no baffle-plates. Not to mention few stoves here have secondary/tertiary burn... .
Anyway, I bought myself a woodstove (brand DRU, quite (if not 100%) similar to Dovre because they are both manufactured in the same factory here) and when I visited stoveshops (which there are few, it's more like a butcher that has stoves for sale also... I'm overexagerating a bit but you know what I mean I think...) both kinds were the same price and the stoves looked absolutely identical (also inside).
I wanted an EPA-approved stove but there are none available. Also would like to mention that those 'stove-dealers' don't even know what secondary burn is... . If I ask them if it would burn overnight they say "Sure, just close the air-inlet, if the glass becomes black thats normal"... . Insert rolleyes here![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
Anyway, with all of the information I found here I dexided to buy myself a Dru 64 CB (Clean Burning). You can find some information but take in mind I have the wood-only stove, which has a 'full' grate like a wood stove should have, so no grates that let the ashes drop. It also has 'tertiary burn' and fireproof stones on the side and the back. You can take a look here but take in mind these are the 'multi-fueles' variants:
http://www.drugasar.co.uk/multifuel_stoves.htm .
The "unique" burning system is what I think is nothing more than absolutely common on new EPA-stoves in the USA. Preheated air coming down the glass (the air heats up because it is going from the back to the front over the stove-top) and tertiary air coming from behind. Primary air is located trough a sort of ash'thingywingy' at the bottem of the woodgrate. The ash-thingy can be full open to remove ashes in the ash tray.
The manual can be found here: http://www.drugasar.co.uk/pdfs/stove_wood6478.pdf
I would very much appreciate it to look at the manual a bit to figure out how this stove works.
My conclusion: it seems the stove is a lot like most stoves in the USA, expect for two things:
- the tertiary burn only comes just above the fireproof stones in the back, so no holes in the baffle plate. Sometimes I can see 'fire' coming thourgh these inlets, but not often. Nice to see if they do however
- there is no 'damper', and I still don't exactly know what this damper where you all talk about is... . I guess it is a system that avoids fumes going up the chimney too fast and let's them burn again in this so called secondary burn chamber.
My question:
Is this a save stove to operate, environmental friendly and capable of buring overnight, still without fuming the neighbourghoud (I can't see, it's winter and its pitch-black where I live at night
)? I set the secondary burn (including airwash), after the wood has burned for 15 minutes or so, to the medium setting. The tertiary air (from the back) can not be turned down. I still see flames, except with big pieces of oak or when I put the stove full of smaller splits of oak. I can see some flames in the beginning, but no flames here after 30 minutes or so, they're just glowing there. After an hour the logs/splits of oak start to flame, slowly with this blue-ish hypnotic-like flame., and after two hours the pieces start falling apart and there are some nice yellow flames. There are still a few hot, red glowing coals after an hour or 7 burried beneath the ashes which makes it easier to start a new fire in the morging.
Is my fire smoldering? Or is this normal with oak (it's dry)? My glass of the stove stays absolutely perfectly clean! The tube going from teh stove to the chimney is always very hot, but I can't finbd any stove-thermometers here![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
When I put in some pine it burns A LOT faster and HOTTER.
Almost never smoke coming into the room where the stove stands, so draft is ok I think... .
Thanks for reading all of this and more thanks for replying!
Greetings
Your Belgian-woodstovefriend (which wants to protect the environment and doenst want any nasty chimneyfires!)
PS: I would have liked to post a picture here, but I haven't got a digital camera (yet)...
My question:
Greetings
