Low Fuel Feed = Just what it says. it allows you to fine tune the fuel feed on heat settings 1&2 only. does not affect heat range 2 and up.
Low Burn Air = just what it says. it allows you to fine tune the air being drawn through the burn pot to give you a good clean fire.
Air on Temp = is a setting the tell the stove when the combustion blower to run. there is no logical reason to adjust this setting above 1 unless you are instructed to do so by ESW for troubleshooting. so this setting is ALLWAYS 1
![[Hearth.com] Englands 25PDVC Bottom 3 buttons [Hearth.com] Englands 25PDVC Bottom 3 buttons](https://www.hearth.com/talk/data/attachments/305/305152-18209a2c79a2047552604b85be90b796.jpg?hash=RJJG6zi-we)
