jjones139
hey there i have englander 25 pdv. 8-1-08 is manf. date. what should the stock 3csettibgs be? i believe my problem with pellet pile up is this.
6-4-1. Make sure you're in D mode as well! Here's the instructions to verify your burn mode.. Unplug the power supply from the wall and plug it back in and within 4 - 5 seconds you need to press both the up-and-down blower buttons at the same time and in the window to the left you will see either A, B, C or D mode in the heat range digital display if you see anything other than D then use the up and down buttons to change it to the proper mode which is D.
