heaterman: The test was [on a Garn 2000] conducted by Intek in accordance with the Thermal Storage Appendix XI of ASTM Document E 2618 – 09, using oak cordwood just like you and I burn rather than the kiln dried cribwood in the EPA protocol.
It was done at the Garn facility using a standard dilution tunnel sampling method and it gave the following results.
88.4% delivered efficiency and more tellingly, only .088 lbs of particulate/million BTU’s delivered output.
I have reported high efficiency numbers for the Garn WHS3200 in prior posts, although not quite this high. It would be very helpful as an aid in improving the 3200 performance to get more information on the Garn 2000 tests, such as:
1) what was the exact MC of the wood, and was it uniform for all wood burned;
2) what were the dimensions of the wood burned, how much difference between splits;
3) what was the weight and volume of the ash and coals remaining in the firebox at the end of the burn;
4) what was the condition of the firebox and the hx tubes, that is, well cleaned such as a user might have after cleaning the Garn before starting a new burn season, or in the condition that might exist after a half season of substantial use;
5) was the Garn 2000 in factory delivered condition, other than installation of sensors;
6) what was the chimney configuration and dimensions used during the test;
7) what was the weight of the wood burned; was it more than one single load; how much by weight loaded and at what times during the burn;
8) what was the low heat value used for the wood:
9) what was the starting temperature of the water in the Garn and was it uniform in temperature;
10) what was the ending temperature of the water in the Garn and was it uniform in temperature;
11) what flue temperatures were measured during the burn and at what location and times were the measurements taken;
12) was the standard, one speed blower used during the entire burn, what CFM; and if not, what was used and what was the CFM;
13) what was the length in time of the burn; was it measured from first lighting until the end; was it measured during some mid-point period of the burn;
14) at what point and why was it determined that the burn was completed;
15) was the water mixed during the burn or after the burn; what method was used to mix the water during or after the burn, what circulator, what gpm, etc.;
16) what was the air temperature in the structure housing the Garn during the test;
17) what was the outside air temperature during the test;
18) what and how much insulation was placed around the Garn for the test;
19) did the efficiency calculations account for heat loss into the structure during the test;
20) did the test measure O2 or other components of the combustion process, other than particulates, and if so what were the components and the measurements.
I think this will help all of us in using our gasification boilers to achieve higher efficiency and greater satisfaction in our gasification boiler experience.
