MacGyver
All three of yours were the new model? Did you try to lower the blower while on high?
There are 9 fan speed settings. While running on the highest feed rate, you can only run the fan on either level 8 or 9.
Hi this morning the readings are between 0.28 and 0.3. When I disconnect the tube from the gauge and try to reconnect it to the stove, my stove gives me an error "P" and shuts down completly!
OK report back in 45 minutes it should be done. So we do see some neg air in room higher than your reading from the stove..not goodSee the stove is on it's shut down process and I am reading 0.35
No the gauge is still connected to the stove and the stove is still on cool down
exhaust fan on? doing a lot of laundry?
SO he COULD run his stove on HIGH while having the blower on any lower speed per the manual posted on the stove's website? No wonder he's warped three stoves!Just to clear things up Ray has had 3 versions of the older model, and still does not have the new style stove. All my testing is for the older style stove.
Hyfire! Had a hell of a week!! Ok I am doing the test right now. At cold I have 0.52, now waiting for it to heat up
Yes it is, got 0.38 when heated up. Closed the window and got 0.33
