I don't even think it would have filled one, wasn't much.. I let it fall onto cardboard on the ground then dumped in the woods so never really measured.. 1/2 would be better, it didn't really pile up or anything on the cardboard...coffee cans quite a bit i think.
None the less you are on top of it Mike and that's great.I don't even think it would have filled one, wasn't much.. I let it fall onto cardboard on the ground then dumped in the woods so never really measured.. 1/2 would be better, it didn't really pile up or anything on the cardboard...
Well unless you measure the 1/2 can that got in my hair lol
It wasn't clogged but its clean now.. The bottom side of the cap was gunkyNone the less you are on top of it Mike and that's great.
I usually get around a coffee can full once a year.
How was your screen?
I usually load even to the top of the firebrick on the sides and then I might add 1 or 2 in the middle that would be above.. that would be a longer hot fireMan this stove takes alot of wood. Once you get above those fire brick your loading against the metal sides and metal back wall which means its wider and deeper above the bricks so its like taking more wood than I thought it would.
I wonder if there would be any benefit to adding another row (horizontally) of fire brick on top of the existing brick in the fire box?
these things react very well to changes in position on the primary air control... once its hot and everything has a good char I only leave it open 1/2" give or take
my experience to get burn tubes going, got to have dry wood, hot stove and a hot coal base,load it with a full load and that seems to be the trick - from a cold start or a reload with very little coals left it seems tough to get much secondary action.. I don't think these stoves are big on secondary action anyways but they must be working as when I am burning there is no smoke from the chimney.
I have a friend that's interested in getting the Myriad but the stove has been redisigned and renamed Myriad II. It now has an added layer of firebrick up the sides and burn tubes vs. a baffle plate. How different do you think the new stove will behave compared to the old design?As it radiates heat exceptionally extra well since the fire box isnt completely lined with fire brick
and it has a stainless steel baffle plate that conducts heat up to the top surface of the stove.
