allFIREDup
The filter is not completely fire proof though. as long as it doesn't come into contact with a flame it should be fine.
I think this is the only way to get it done w/o any CFM reduction. Even the biggest mesh furnace filter material I used showed a pretty significant reduction in airflow........Using duct adapter/reducers you can increased the diameter or use a duct register boot. I have also seen flexible duct used to relocate the inlet and connect it to a filter box to hold a larger filter......
the magnetic tape isn't strong enough to secure something like that.Just took a quick blip to the hardware store. Couldn't find anything except those steel wool looking kitchen scrubbers. MUCH coarser than #4 (or whatever it is) steel wool. Unfortunately, they only had one in stock.
I'm thinking make a cylindrical "box" with 1/2" chicken wire stuff on the bottom and magnetic tape to secure it. Place 6 or 8 scrubbers in there. When they get dirty, you'd probably only have to replace the top layer of pads and be good to go. Not sure if they'd reduce the flow but it may only be a trivial amount. They're very coarse...and non combustible![]()
As long as your turbocharged blower doesn't pull more current than the control board can handle.To overcome this you will need a more powerful blower to deliver the operating CFM that it was delivering before the added filter.
Speaking of pulling more current; As the static pressure increases due to filters, ducts and such, the current drawn by the motor will increase (the motor is doing more work). The motor will run hotter and the control circuit will run hotter. Not necessarily a problem, just something to keep an eye on.
it wouldn't hold the contraption i made and my contraption weighs much less than a pound. i needed 4 small round extra pull magnets from a hobby store...they are the size of a watch battery.You don't think so? Can't imagine the proposed contraption weighing more than a pound or so.
You just need to have enough air supply that reaches the blower intake, lots and lots of smaller holes will allow that to happen.
You have to be certain that there are still unplugged holes for air flow through the filter over a certain time span.
Most stove shells have holes in them for this purpose.
You add the filter to the stove not the blower.
The blowers intake is approximately 28.3 square inches on my 230 CFM blower.
An appropriate filter size is going to be much larger than that and installed on the stove shell if one were to look up the effective air flow cross sectional area of the filter material one can size the filter to the air flow need plus slop to handle the build up.
Say along the size of 20" x 15" or 300 square inches
An even better setup would be an electrostatic filter system to pull the crud out of the air stream as this wouldn't block any air flow and only needs to be big enough to get that crud off to the sides.
All air filters added to a system create static pressure which reduces CFM. To compensate, an increase of CFM is required to give the same air delivery.
If filtering the stove shell the same terminology applies if the stove shell is air tight other than intake ports.
I think the fan will likely run at the same amperage no matter what static pressure it sees. In some heating systems a static pressure sensor is placed to maintain a constant pressure. For example, if a filter gets dirty, the pressure drops in the system so the sensor could relay that and increase the amperage.
Actually the amp draw goes down as the fiter gets dirty. There is less load on the impeller. So less load on the motor.
So the control boards are smart enough to see a load decrease and vary the convection blower amperage based on that alone?
