Woodcutter Tom
How long is that thermal probe?The hole the the thermal probe is in was already in the adapter. I added the hole for the damper.
Does it measure the center of the flue?
When you pulled it our 3 inches, was it at the edge of the flue? Tip touching the flue?
Does the probe contact your damper plate when you rotate the damper?
Do you already have the magnehelic or manometer?
Have you considered inserting the magnehelic or manometer tubing into the temp probe hole to temporarily test draft?
Is there SS flexible liner under the hose clamp and what looks like foil?
