I purchased 2 hearthstone wood stoves about 3 years ago. I paid 3500 for both including installation. I have the heritage in my living room. The air intake is underneath the stove near the air control. Carefull feeling around under there, if you have your finger in the hole an move the lever it could cut your finger off.
Now.... If you are burning kindling and it goes out quick it sounds like a clog. Even with the damper closed you should still get a fire. LET ME TELL YOU. if you have ANY type of wet wood you will have a hard time getting heat. These stoves are a little to high tech in some ways. Every year I have to fight with a wood person to get me dry wood. The wood must be dry
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
! If not it will build up creasol and clog your flu and you will be out of buisiness. If the wood is wet, just toss your money out the window and put on a coat.
You have to be careful when starting your fire for the first time every year. You must burn 2-3 small fires to dry out the stone or it will crack. I have a fire going now with last years wood and it works great, turn the air back and watch the fire dance. MY biggest problem I cannot get dry wood.
These stoves are made of stone, there is no iron to give off heat, maybe the door and legs its just framed in stone.
Heres my question due to my wood problem, I am looking at going pellet, Do you think a use Harmen accentra for 1600 is worth it or a refurbished Hudsonriver Niagra-new is a better deal. Im stuck on this one.
