Flatbedford said:
So do we conclude that the need for 20% MC and years of seasoning are a myth? Or, is there more to seasoning wood than simply lowering the MC? Does the seasoning do something else top change the wood? Has the cellular structure been altered? Density changed? I know that well seasoned wood just feels different than green wood. Scientifically speaking what besides MC changes as wood seasons? Remember that most species also get harder to split and cut after being seasoned too.
Conclusions:
Like most of the threads I start, this one is a stealth thread. By that I mean that it's not at all about seasoning wood, or how well a split of "X" MC will burn in an EPA stove. It's entirely about using a moisture meter correctly for your needs as a woodburner.
When we were standing outside the Woodstock building and I tested the freshly-split white ash at 28% MC, it was all I could do to hide a smirk. "Surely, this is telling only a portion of the real tale", I thought. "If only I had this split in hand back home, I could do an oven-dry test for MC and find what it really is." Tony graciously sent it my way, so I was only too happy to do the test.
Nearly every poster I have seen post results of their meter reading seems to have the wrong idea about what this reading means. Those I have spoken to seem to want to ignore the fact that their meter is calibrated to give a reading using a dry-basis calculation. At the Woodstock gathering I was explaining the huge difference between the two methods and a member implied that I must be using some sort of voodoo math, maybe like David Stockman used to invent Reaganomics. Sorry, but it's the same math we used in grade school, just applied in a manner most people think is wrong. Too bad the people designing and using these meters in an industrial setting think otherwise, because for their purposes, they work perfectly fine just as they are.
For some reason, burners here don't want to believe that the meter is giving them a different result than they are looking for. They believe that the meter is giving them the percentage of water by weight that is present in the original wood, but in fact, it is giving them the percentage of water by weight compared to the weight of dry wood fiber in the sample. The difference can be huge. In short, if you don't understand the relationship between wet-basis and dry-basis calculations, you might as well throw the thing away.
The only thing that matters to a wood burner is the wet-basis calculation. It is consistent throughout it's range and is linear in relation to water content variations in the samples. Simply put, what you want to know is how much water is in a split weighing "X" pounds. The meter will not give you this information directly... you have to use a simple arithmetic formula to get what you want. I wish it wasn't so, but it is very true.
The formula was stated in bold text in the original post. I'll try to say it differently.
Take the reading on your meter and add 100 to it. Then divide the meter reading by the new (higher) number. For example, let's look at a split of red oak (Red oak needs no species correction) that reads 25% on the meter:
25+100=125 25/125=20% MC wet-basis, or 20% water by weight. 5% lower. Big difference, eh?
Let's try another one, a split of douglas fir (also needs no species correction) that reads 33% on the meter:
33+100=133 33/133=25% MC wet-basis, or 25% water by weight. 8% lower. Bigger difference.
How about a 50% reading (I'll ignore the fact that meter aren't that accurate at that MC)
50+100=150. 50/150=33% MC. 17 points difference! That's enormous, and it gets progressively more disparate as the MC climbs.
If the meters actually worked beyond that point and used the same calculation method, a piece of wood that is 50% water by weight would read 100% MC on the meter, and one that is 2/3 water by weight would read 200% MC on the meter! Mind-numbing... but true. If you don't convert this you will have no idea how much water your wood really contains, simple as that.
How would you feel if you were driving a car that displayed your average speed on the speedometer instead of the speed you're actually traveling at? Or one that gets progressively further from the real speed the faster you go. In meter speak, that would be like seeing you are moving along at 20 mph when you are only doing 16, or seeing 25 when you are doing 20, 33 when you are doing 25, 50 mph when you are crawling along at 33 mph, or 100 mph when you are really cruising at 50.
Burners using meters also want to blithely disregard the importance of species correction needed in using any meter... and the more significant problem of actually having enough experience to be able to identify the species in question. This makes meter use very problematic for new burners who aren't sure if they have either hickory or tulip poplar... a difference of 5 1/2 points of correction between the two.
When I did the oven-dry MC assessment on Dennis' wood, I quoted it in dry-basis terms (like a moisture meter would read), and then converted it over to wet-basis terms (like a stove designer would speak of). In simplest terms, I drove out every last bit of water - 54.2 grams - from 306.6 grams of well-seasoned ash. That is to say, the wood was 17.7% water by weight, even though the meter said it was 28% inside. And 17.7% MC is almost exactly between the the lower and upper range of MC used when your stove was originally tested for those emissions and heat output numbers it is supposed to have. The EPA test calls for using wood that is between 16% and 20% MC wet-basis. Is it any shock that it burned so well in the Woodstock stove? Why wouldn't it? At just under 18% MC, it's simply perfect.
Bottom line? Wood needs to be seasoned, it's just a question of how dry and how long it takes to get there. A general guideline is that it needs a minimum of a year stacked outside, two is better and three might be better yet in some geographical areas. But if you grab a split of hickory from a two year-old stack and crack it open only to find out it's still reading 28% MC on your meter, don't be alarmed. It's really telling you that your wood is at 20% MC in the very middle, and that the average MC for the entire split is even lower.
BTW Dennis.... have you fallen asleep yet?
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
