Thank you for checking...and confirming my claim.
Actually, it proves you wrong. You said, "I think that atmospheric CO2 historically has not changed 50% in 100 years anytime in the last 200000 years," when in fact it has changed as rapidly in the more distant past as it has in the recent past. If you want to attribute the current change to humans, then how do you explain the previous ones? Moreover, it is obvious that CO2 changes, while correlated, FOLLOW, not precede temperature changes. This is due entirely to ocean solubility. CO2 does not cause temperature to increase in any significant manner because it is saturated already. CO2 concentrations have been as high as 7,000 ppm in the past (almost 20x higher than current), and the Earth did not boil.
Also, comparing ice core data to current air sampling is not fool-proof, so looking at past fluctuations may be very attenuated compared to current sampling. Maybe it has actually fluctuated by hundreds of ppm over very short periods regularly in the past, even more so than they already indicate (which is already very volatile), but ice cores don't capture it. Plant stomata data show much more volatility of CO2 levels over the last thousand years than the ice cores do. CO2 levels have often exceeded 300 ppm, including a 120 ppm increase from the late 1100s through mid 1300s. So simply comparing Mauna Loa air sampling to ice cores and concluding that we're in a suddenly vicious up-trend never before seen is naive, especially in light of the massive hockey stick errors already shown.
The fact of the matter is that temperatures began rising some 250 years before CO2 levels started rising during the present warm cycle. That is not an indication that CO2 concentrations are causing warming, it is an indication that warming (a trend started pre-industrial times) is causing the dissolution of CO2 from the oceans.
And remember....the models suggest that such rapid changes may create 'dustbowl' drought conditions b/c the ocean temps take a couple centuries to catch up. You won't find an example of that in the fossil record, b/c such rapid change has never happened before in the period for which we have such data as above.
Remember, those models are crap. We know right now by actual sampling that that claim is bullshit. Warmer temperatures cause more clouds and more rain, right now. I quoted a NASA climatologist earlier in this thread in that regard. Droughts are caused by cooler temperatures which prevent as much ocean evaporation. Warming causes more clouds and rain.
To build a working model, you have to try different things, and see which one works best. Perhaps there has been some advancement since 1993?
Nope, because the original hypothesis failed, so any future models built on that same hypothesis will also fail. And have.
Actually, This one bears emphasis with regard to your "petition".
Again, I have no desire to play the game of which scientists are smarter. But I could play it all day. UN IPCC Japanese Scientist Dr. Kiminori Itoh, an award-winning Ph.D environmental physical chemist has decried that warming fears are the "worst scientific scandal in the history... When people come to know what the truth is, they will feel deceived by science and scientists." So keep telling yourself that all of the scientists who have helped compile IPCC documents all come to the same conclusion as the politicians who write the executive summaries for policy makers.
I conceded that the 20th century record is too short to say anything compelling about climate change in my very first post in this thread. This is obvious to the layman that looks at the graph. Sure there is a wiggle upwards at the end, but there are enough wiggles that ones gut instinct is that you wouldn't bet the farm that the line couldn't wiggle down next year or for the next 10. And that lay intuition is right on...we are all wired to do statistical inference whether we know it or not.
And yet all of your arguments stem from the idea that we're looking at something unusual in all of history.
The fact is that deniers have tried to pretend that all of climate change science hinges on interpreting that one plot, and it simply doesn't. You insisting on moving the topic back to that one useless plot seems like denier behaviour.
Actually,
skeptics don't have to pretend anything. They must merely poke holes in the true believers' false contentions.
I am actually more worried about the future tyranny that would result when the climate SHTF. But I am enough of a technooptimist to think we wont get there.
Especially if there's no rational path to get us to anthropogenic climate SHTF. Now natural climate SHTF is another thing altogether, and I really wish society would overcome their normalcy bias and realize that things can change very drastically very fast through no doing of our own. In fact, long periods of stability are very, very rare. As I mentioned previously, most civilization collapses throughout history have coincided in rapid downturns in temperature and upticks in geological activity. Both of which we seem on the verge of experiencing.
You work this stuff out on your own Thomas? The industrial release stuff is easy peasy....countries keep records of fuel use over decades, and the emissions are ~2x the rate of increase in the atmosphere, the rest goes into your buffers. A nice accelerating linear trend both for the new CO2 appearing and the estimated release. Small errors on both...and the confounding fluctuations (as in the temp records) are way smaller. You can even see features related to the 1970s oil crisis, the great recession and China's recent economic expansion. All in the CO2 over Hawaii. Heck, now they can visualize the plume of excess CO2 coming from industrial regions, spreading over thousands of miles.
There you go confusing correlation and causation again. Check the temperature record first, then see how CO2 responds. You can't just cherry pick a few instances where temperature-driven CO2 changes happened to correlate with human events, Nostradamus.
