Wood,
It looks like you have spent some time looking into climate change issues.
A couple climate change related questions/issues that have been troubling me -- maybe you could give your take on them?
1) The tipping point idea that Jim Hansen and others have been describing. Basically the idea that modest changes in one of the climate forcing functions (like CO2 above about 400 ppm) can start feedback mechanisms (eg less ice to reflect solar, methane from tundra etc.) that end up resulting in climate and sea level changes that are well in excess of of what the original CO2 increase would generate on its own, and that would be beyond our ability to control.
They appear to have found evidence in the ice core record that supports these kinds of episodes in the past.
I believe that the IPCC predictions do not include these tipping point effects(?), so the end climate picture could be significantly worse then their predictions?
2) The idea that the standard calculations and models have assumptions and tolerances that could make things better or worse than the nominal predictions. A lot of people like to focus on the positive side of this saying that the outcomes may not be as bad as the predictions, but what about the negative side -- what if errors in assumptions are such as to make the actual outcomes worse than the predictions? I believe that the cheif scientist of NREL (I may have that title wrong) has said that if you change some of the underlying modeling assumptions by modest amounts, the end effect is large -- especially in terms of sea level change.
These are bothersome to me in that you always like to at least be prepared for the worst case outcome, and if there is truth to either of these areas, it seems to me we are far short of being prepared? Maybe we are far short of being prepared even without these potential added effects?
Gary
I am far from an expert, but I understand (and have taught) the basic physical principles involved.
It is my understanding that the direct temperature 'forcing' is well understood and larger than observed,
and the feedback effects are less well understood (and climate records are not really that useful b/c of the
unique nature/speed of our current 'experiment'), but are, overall, generally accepted to be negative. This
reconciles the small warming from the data and the large predictions of simple physical models.
That what I said earlier.
To me, that is a good place to say stop and engage 'skeptics' who think that the basic phenomenon is implausible, and
based solely on poorly understood feedback effects from climate models. In fact, if simple physical models (that are not
debatable really) were correct, we'd already be up the creek. The warming we see, far from being implausible or
needing to be explained, is actually smaller than we would have estimated by physical 'laws'.
Back to your question....clearly ice is a positive feedback. Again, I am not an expert on the finer points, but I think
when the ice is gone, the positive feedback is maxed out....ice can cause an oscillation between a cold and a hot
state (like an ice age or an interglacial state) but it isn't clear how it superheats our current climate further.
So, I'm basically gonna cop out on your question....there is a lot of hype in the press about permafrost and methane
and tipping points and I am going to wait for all that to be a bit better settled. But I think the scientific community
and press may be confusing the public with all this new, less well cooked science....
Imagine if in 1972, there were a flurry of press releases about how smoking was even more likely to kill you b/c
it also caused obesity, made you a bad driver, caused pneumonia, etc. But all of those articles ended up with 'but of
course this needs to be confirmed in future study'. And in all that noise, the already well demonstrated fact that
it causes lung cancer got lost, and then the cig companies started poking holes in all the new studies, often
correctly, by showing that smoking doesn't make you fat. The result would be an unholy mess. But smokers
would still get lung cancer.
So, you can put me down as a non-skeptic/non-alarmist for the present (i.e. I am skeptical of the latest science
of tipping points, but try to be open minded) but non-skeptical/alarmist for the prognosis on 2100.
Pushing my smoking analogy further....you're a doctor and a 22 yo smoker comes to you and has been smoking heavily
for 5 years. You have to tell him that if he quits now he has a much lower risk of getting lung cancer than if he
keeps smoking for 20 more years. The good news is that if he quits now his chance of cancer is low (but still not
zero). But he also has to get that the risks of continuing (after a long time) are very high.
But if he doesn't believe that cigs cause cancer...can you convince him to quit because it smells, or he might
burn his house down accidentally? IF you throw too many reasons at him, does he start to tune out??
