ok, now that the contest is over (again) , has anyone given this gentleman any ideas on what size unit will work best for his application , i havent re-read the whole thread, got disgusted and just scanned) anyway, who has ideas (whether cat or non-cat) which size and type will work best for him. jeez peeps, he asked for help not a chest beating contest! i am now going to go back <sigh> and read this thread up to the point it got outta hand and see if we can get this thing moving in a positive direction
EDIT
k i have done my reading and dug out the size of bills new home (planned size), a unit rated to heat up to 1800-2K SQ ft would actually work well in both situations, 700 SQ FT is small, but uninsulated, therefore bill will need somthing that will heat at least 2X square footage (possibly) to keep temp in that space, obviously looking for a modern unit which will reward him with long burn times as well as required heat output. now there are several units which will fit that bill as 2K sqft is easily attained with most units with 2.0cf firebox and reburn (be it cat or non) system. personal note to bill , go a bit big rather than small in your zone IMHO, anyway, the deal with cat vs non cat is this in my opinion (being an owner of a 2.4cf cat unit rated at 2200 sq ft cat stoves tend to be a bit more cumbersome to operate , they do require a strong draft, and are usually slow starters compared to older smoke shelf units. non-cats are usually a bit easier to operate, i do think some cat units do give longer burn times, but i do NOT think they are excessively longer, i have personally had 11 hour burns where my catalist was in the active range(above 500# F ) but i have also seen personally our 30-nc series units burn for that long as well. the 30 is a larger firebox 3.5 vs 2.4, but the wood load was pretty much the same as the 30 is loaded only to the top of the bricks where the 24 i have at home can be stuffed to the rafters. if you are experienced with operating a cat unit then you will know how they perform and likely would be happy with one, if not then you may not be. my worry is the statement that you would prefer somthing that gives heat fast, that says non cat to me. anyway, the guys will im sure chime in on the virtues of the units they prefer, to you i would ask , listen to their descriptions, to the guys Please dont get into the chest thumping again, lets do what we do best i hope you find this helpful bill, let me know if i can be of service in the future
EDIT
