Corie said:Roo and Gunner,
The Super 27, Fusion, Classic and Spectrum are all in the 1.5 cu. ft. firebox range and don't feature EBT, as far I can tell. Its hard to believe that 1.5 cu. ft is good for 2000 sq. ft. of heating as they say on their website. But assuming they aren't over listing those stoves beyond their capability, they certainly seem like overkill for his cabin in its current state.
I know that Pacific Energy stoves are wonderfully engineering and constructed pieces of heating equipment and I don't mean to take anything away from that. But how can a 1.4 cu. ft. firebox possibly give good strong overnight burns without EBT? My stove is 1.6 cu. ft. and stretching it beyond 7 hours with any useable heat is basically impossible.
Also, since by the manufacturer's rating, the Super 27, Fusion, Classic and Spectrum are all probably on the large end of stoves he could use, he could certainly accomplish lower BTU output by simply putting less wood in the stove. How though, does that work into the equation when the weather is mild? A 40 degree night is going to require a small fire in the stove, which means little wood, which translates into a very remote possibility of an overnight burn, even though the heat will be needed throughout the night because of the heat loss of a relatively poorly insulated cabin.
This is where I think the catalytic stove comes into play. A catalytic stove can be loaded with wood, allowed to reach cat operating temperature and then cranked down to burn extremely slowly with low heat output. It doesn't necessarily require tiny loads of wood to accomplish diminished heat output.
I know you Pacific Energy owners are gung-ho on these stoves, but I just don't see how any non-catalytic stove is the solution for a small space like this.
Bro, the thing your failing to think of is:
You can fill the firebox of a stove up, and not run it at 600 degrees. If you fill it and run it around 400-450, it will burn all night & not cook you out of the house. If you use a smaller stove doing the same thing, less load at same temp lasts shorter time. And higher temps even shorter burn times. My Insert doesn't even come close to cooking me out of the same room its in, granted I have very high cathedral ceilings, so that does play a part. What Gunner & Roo are trying to say from what I am reading is, he has a 750 sf cabin now, but is building a newer home in the next 6 yrs. If he is building a much larger house in the future. A smaller stove now will not be sufficient then. Unless of course he can buy another bigger stove and use this one also.
Why must there always be arguments about P.E.'S and VC's. Etc etc etc. We boast of our stoves because they perform well for us. VC's are boasted for because they perform well for their owners. So mine puts out more gph then the others. I am still putting out far less that my old pc of crap. Not to mention I am burning on stove as other may be burning 2, and even if lower gph, that doesn't account for the amount of wood they are burning in the 2 to my 1. I have had enough of numbers etc. I love my stove, am happy with it, and I know I have lower emissions than my old insert had. Ids it the best? I won't say yes or no. Does it perform how I need it to? does it heat my house? Am I not burning oil, You betcha
! I can heat this place at 300° or 750°. just depends on how cold it is outside, and how warm I want it inside.I have never been baked out. But again, my house is farily optimal for my setup. I am luck in that regard.
