That Striker is the little stove that can! It sure looks nice in that setting.
How cold has it gotten down there. CG?
WES999 said:pen said:Steel stoves can take quite a bit of abuse.
For future reference, some people have actually found that they can drop their temps by opening up the primary air all the way or even opening the door. It seems counter-intuitive but doing either thing shifts the balance in the stove away from the secondary burn action which is getting the stove top so hot.
My wife has a tendency to see the stove do this sort of thing quite often. As such, I installed a flue pipe damper and when she's got things ripping a bit more than she anticipated she closes that down which reduces the draft and helps regain control.
glad it didn't split in 1/2 (BTW, my stove saw 904 °F on the IR the other night after one of the aforementioned loads) This is why I think I'll only ever own a steel stove and will only ever buy one of the plain Jane budget friendly models like I have. If this gets tweaked, I can buy another and still be in it for less than the cost of one of the more expensive brands.
pen
I don't think I would recommend that, while it may cool down the stove top I think that flue temp would go sky high.
I just did a little experiment, my stove top was at about 550* and the flue temp was at about 650*, I opened the door slightly and the stove turned into a blast furnace, the flue temp went up 300* in less than a minute. :ahhh:
On my stove I like to keep it under 700* My blower will turn on high at 675*, even with a full load of pallet wood it generally won't go above 700*
I think if your stove is getting too hot, turn on the blower on high, if that does not work, plug the secondary air intake with foil, that should bring the temp down quickly.
Backwoods Savage said:WES999 said:pen said:Steel stoves can take quite a bit of abuse.
pen
Actually Pen is right on! It does sound wrong...but it works. I think fire_man also posted one time about his stove going wild and he recalled one time I talked of doing this very same thing. He opened up his draft and the stove cooled. Yes, it will take the flue temperature up for a short time but should not take it to any where near the critical point. Just remember that we are talking about a very short time here to have the draft full open. The stove cools and then you close it down again.
We had a case of the same thing here one time this past fall. My wife was going crazy when I came in. Seems she was having a problem keeping the stove top temperature below 700. I walked over and opened the draft, not full open, but about 30% open. The stove top cooled down to 650 in no time at all. She had forgotten about that little trick but hopefully she remembers it now.
Also, on your experiment, you stated the flue temperature was 650 with stove top 550. Then you said the flue temperature went up to 300. Something is wrong there...
BeGreen said:That Striker is the little stove that can! It sure looks nice in that setting.
Thanks Gamma Ray! That was our pug girl Chyna I lost a couple of years ago to PDE. Broke our hearts.GAMMA RAY said:Beautiful hearth and stove Thanks for posting pics. I don't even go near the door without my welding gloves on Just in case....By the way, great avatar pic!!
GAMMA RAY said:So cute....Sorry about your dog, they do become a part of the family. Don't have one, only a parrot but I love pugs and now I want one along with the 30.....I gotta stop frequenting this site.......I keep getting all these new ideas......can't help it!
