alan323 said:Check my Sig. There is a link to some cleaning instructions there it might help.
MacP said:alan323 said:Check my Sig. There is a link to some cleaning instructions there it might help.
Great step by step instructions. Thank You! I gave my stove a good cleaning today. I should probably wear a mask next time. I haven't cleaned out the vent pipe. It's only two weeks old. It should be fine.
MacP said:Should I be scraping the inside walls in my pellet stove?
Tony K said:I will clean my stove at least once a week, but how the pellets are burning (lots of ash or little ash) determines how often I clean my stove. I do as most here have said, I will clean and scrap burnpot and vacuum out inside of the stove, clean the glass with either a generic window cleaner or lately I have been using Rutland Conditioning Glass Cleaner. I do wipe down the glass twice a day with a cloth such as a hand towel. I will pull off the combustion blower (exhaust) usually every other month. I believe this is important to do as the ash will build up on the fan blades (making the blades heavier thus making bearing life shorter) as well as on the plate. Be sure to have extra gaskets on hand as these are one time use. While the combustion motor is off I will also run a brush through the vent pipe.
MellieNH said:I used to use Windex for the glass. It is still a lot of work to get it really clean. Then I tried that oven cleaner that comes in a spray can. WOW! Talk about a fast and easy clean. It gets it really nice, just like new.![]()
Trefix said:+ 1
A clean stove is an happy one !
