I bet you're rightThe secondary tube was fed with a fan as well. which is probably why it wasn't firing.
I would think you would want natural draft only (for both primary and secondary) so the air velocity would be low enough to pick up as much heat as possible...(remember that 1200* mark)Should the secondary tube be natural draft only or can some induced air flow be ok?
So the secondary air pipe will run through the coals before turning up to the top? That would make for some hot coals once you get to that point in the combustion cycle (probably coals there all the time once full time burning is commenced)I tried to dig up the best picture I have "side view" of when I was building my boiler to show where my air flow is entering.
So here it is. you can see where my water jacket falls on the fire box, my heat exchanger box, and my air flow pipe. the blue arrow is showing current air flow coming in under the fire grate (red line).
And this is what I'm thinking about doing to get my air flow up into the back of the coal bed. I have 2 weld elbows that I'm going to add in to get the air up above the fire grate.
I know it's rough drawings but will this possibly help with getting the air where I need it?
