Mine is removable and just rests in its place (no adhesive). Not sure if that is how it is supposed to be but mine has been functioning just fine.
sullystull said:Mine is removable and just rests in its place (no adhesive). Not sure if that is how it is supposed to be but mine has been functioning just fine.
Still working on the everburn, I can get short rumbles that peter out after a few minutes today, but not sustained yet. Huh, just got it going and it sounds like it's going to continue. I think my original "build a coal bed" load of wood was too far burned to be releasing much gas and the new load wasn't going enough to release gas.
The comments about smaller splits sounds important, more surface area to off-gas the volatiles so a higher concentration of gas to burn. I have not gotten around to re-splitting wood to smaller size yet. When I was splitting I was shooting for largest splits possible for longer burn times, so I'll be downsizing my splits in the future.
When you have the everburn going on high and turn the air lever down to lower does the rumble drop in intensity or stay about steady?
Exterior air, yep it's controversial, but for me this is a super easy install (got parts at Lowes yesterday for $16 and it will take 5 minutes to drill a hole in the floor and install) and I'd rather be passing cold air through the stove from the outside than putting the building under negative pressure and sucking that air into the building then into the stove. However, Gordo's comment about running exterior cold air into stove making everburn harder to achieve has me rethinking that a bit, then again 20 degree exterior air vs 60 degree (floor level) air when it needs to heat into the 600 degree range to everburn isn't that much extra energy for the stove to put in.
Last and most troubling for the day. I let the fire totally burn out last night, extended the chimney today, went to start another fire and layign on top of the ash bed was a piece of ceramic. not a chip, the whole piece.
BurningIsLove said:Yep, its just the firebrick that rests N->S inside the side loading door. I've knocked mine over a few times over the years, dont worry about it. Just put it back and you'll be fine. No need to apply it w/ adhesive, just be mindful of it when loading new splits.
tradergordo said:I'm curious to know what kind of heating results you are getting with that setup? Its a big stove for such a small space, but obviously that is offset by the low insulation.
Central_PA_Chris said:Still on the steep side of the learning curve. This is day 6 of fires (well one 8 hour fire then a 8 hour break and pretty much 24/7 since. Got the flue probe in last night and found I was trying to fire the everburn at too low a temp. With damper open and air control on high I was only getting around 400 degree flue temps even after protracted burning. With the ash door open a bit I got the flue in the 700 degree range, engaged everburn and boy did it roar, stack temps shot up to about 950 for 5 min or so before dropping back into the 700-800 range. I let it go for about 10 min then air controlled back to 2/3 everburn, which then petered out. Fired it back up and let it run on full air control, I think that it kept everburning but I was asleep fairly quickly so who really knows.
I have noticed that when I engage everburn there is frequently a little puff of smoke from the spot where the air control lever goes into the stove also seems like with the damper open and air lever fully open that even with a really hot, good fire going my stack air temp is only around 400.
Seems like even if everburn fails, running with the damper closed (as the air takes a more circuitous route through the stove and can throw more heat into the room) is more efficient than damper open.
Flue probe helps a lot and that's only been here a couple days.
so draft should be ok. The puffs were only RIGHT when I closed the draft control door, and very brief/hard to notice. Seen maybe twice, could have been when doing 400 deg everburn start attempts. Have not seen anything like it from chimney pipe joints etc.BurningIsLove said:Central_PA_Chris said:Still on the steep side of the learning curve. This is day 6 of fires (well one 8 hour fire then a 8 hour break and pretty much 24/7 since. Got the flue probe in last night and found I was trying to fire the everburn at too low a temp. With damper open and air control on high I was only getting around 400 degree flue temps even after protracted burning. With the ash door open a bit I got the flue in the 700 degree range, engaged everburn and boy did it roar, stack temps shot up to about 950 for 5 min or so before dropping back into the 700-800 range. I let it go for about 10 min then air controlled back to 2/3 everburn, which then petered out. Fired it back up and let it run on full air control, I think that it kept everburning but I was asleep fairly quickly so who really knows.
Where is your probe located, e.g. how far removed from the flue collar? 400 does seem quite low for a probe, but not for a surface magnetic. What is your stove top temp when the probe reads 400? I think we might have a mis-communication on terminology, as 400 on my flu gas is like a brand new, barely above smoldering fire.
Please, please do be careful if you are going to attempt to burn w/ the ash pan door cracked open. As I'm sure you've noticed, it can be quite a jet engine under such circumstances and is not recommended for safety (and warranty) reasons. Never EVER leave the door open unattended, even for a few seconds, and never more than a crack. I long ago abandoned the practice.
Yes, this is the back puffing scenario. When the draft is insufficient to draw the gases into the secondary combustion chamber, they instead accumulate in the primary chamber. At a certain point, they ignite en mass and there is not enough space to force them up through the fountain/chimney, so the least point of resistance is out the primary air lever. This is also dangerous....if you see that happen, open the bypass, and adjust your splits & coal bed, making sure there are no obstructions in front of the refractory shoe. Let the stove & fire heat up again a few minutes, then close the bypass and try again. You dont want the stove to repeat that pattern of back puffing.
It will prolong burn times, but it's not more efficient or prone to throw more heat. When it 'stalls', both the primary and secondary are starving for air. You arent getting any additional heat from the secondary as there is no secondary combustion...so you're letting smoke/waste gases escape out the chimney. It will also cool to the point of producing excessive creosote and can be a fire hazard over time. It's safer to run a hot fire w/ the bypass open, which will heat the cast iron and throw a lot of heat, than to starve the whole system and get the longer burns.
Central_PA_Chris said:To add insult to injury, when burning 24/7 the front glass only stays clean for a couple days (and one error on air control or wood stacking and it gets ugly quick) before you start a cycle of black buildup after loading/fire cool that burns off when a hot fire is going to a gray soot that's easy to clean, but gotta have the stove cool to clean.
Central_PA_Chris said:Anyone have any tips on calibrating a flue gas thermometer? I noticed on one of my cool down cleaning cycles that it was reading around -200 (markings don't go that low, so thats an estimate/extrapolation) I think that may be why my flue gas temps don't match others here.
Central_PA_Chris said:Anyone have any tips on calibrating a flue gas thermometer? I noticed on one of my cool down cleaning cycles that it was reading around -200 (markings don't go that low, so that's an estimate/extrapolation) I think that may be why my flue gas temps don't match others here.
Central_PA_Chris said:I will admit there are some not-perfectly dry logs mixed in, though the majority seem really dry. Basically I had a log pile sitting for a couple years and stacked it this fall, so the wood with ground contact is less than perfect, but the rest is probably as dry as I expect wood to get without superdrying or a kiln.![]()
In a pinch, you can just mix in pallet wood 50/50 with your crap wood and hope for the best but even that might not work so well.Nostrum said:I've been running a new VC Defiant NC 1610 just about 24/7 since the end of October. Slowly learning why this stove is refered to as a "Neverburn" after considerable reading in this forum.
Setup is a horizontal vent into 8" insulated SS chimney liner that runs up through the old masonry fireplace chimney in my single story home.
I've had considerable trouble getting the Everburn to engage all season. This past week Everburn has been really difficult. It's been quite cold and I'm freezing. Having trouble keeping the main room close to even 65 degrees. Obviously not getting any secondary combustion. Can't get the griddle temperature over about 450 after shutting down the damper. No rumble even after letting the griddle temps go up to 600 before damping. Been running the primary air control wide open all week. Chimney liner was cleaned less than a month ago.
I'm considering removing the flue collar this weekend to clean out around the sides of the non-cat. I saw some mention of also removing the shoe and gasket. Is this necessary?? Could someone help and post exactly how to remove the shoe.
Thanks.
Nostrum said:Is it necessary to remove the refractory shoe for good cleaning, and if so, how is it removed??? Don't want to damage anything.
Central_PA_Chris said:That long burn load technique, so it's sorta like vertical (12"?) bookends of splits on both sides with (agian around 12"? long) splits stacked horizontally in the middle?
Central_PA_Chris said:Sorry, my bad on the firewood explanation, it was cut to length, not full logs, probably 30% rounds that didn't need to be split and most of the rest just needed halved and that did just get split this fall. No really big, many splits from a round, wood. All piled as if dumped from a dump truck that was slowly moving forward, pretty much surrounded by a gravel lot, so not in weeds and briers, it's the bottom of that pyramid of wood that I suspect didn't get seasoned. Maybe you hit it dead on, but it split as if dry, weighs in hand as if dry, pop a chunk of bark off and it's bone dry underneath. I've got other wood that's in full tree form that I'm cutting and splitting now (for next year) that's been downed for six months to a year with bark on and that stuff is wet, you can really feel the weight difference and the bark doesn't come off at all while splitting.
Well, I've been pondering your post for the last 12 hours or so and went looking for moisture meters, found ok looking ones for $20 so I ordered one. If $20 can get me piece of mind, I'm buying. I hope your right and my wood is just too wet, that would give me a bunch of hope for next year (and motivation to keep splitting and stacking now).
dtabor said:Diabel, I have to say your setup must be much different than mine. I take off my flue collar 1x per year to get the ash down in the back areas and it is the biggest PITA. As much as I hate ladders, Id rather clean 50 of my chimneys 32 feet up. The only way to get at this area, I have to remove the whole horizontal piece of pipe then trying to get it lined up again is a bear........
tradergordo said:Central_PA_Chris said:I will admit there are some not-perfectly dry logs mixed in, though the majority seem really dry. Basically I had a log pile sitting for a couple years and stacked it this fall, so the wood with ground contact is less than perfect, but the rest is probably as dry as I expect wood to get without superdrying or a kiln.![]()
Sorry man, but dead trees lying on the ground for a couple of years rarely make for good firewood, doesn't matter if you stacked them last fall or last spring. Also, splitting and stacking wood in the fall might be OK if you are burning it a year later, but its definitely NOT good if you were planning to burn it over the next couple months. Most people don't even count seasoning time until its split and stacked, that means your wood has been seasoned for about 3 months. That right there is going to give you a bad experience with just about any stove. I suggest you go out and find a big pile of free pallets, cut them up, and burn that for a few days to see what the stove can doIn a pinch, you can just mix in pallet wood 50/50 with your crap wood and hope for the best but even that might not work so well.
I tell you the truth - I've definitely grown to like this stove better over time, particularly this year with the colder weather. Its about 10 degrees here right now (which is pretty cold for Pennsylvania) and the stove is kicking butt, the house is 76 and I've been getting easy 9 hour burns every day pretty much all season. I got an 11 hour burn today while at work, even though it never got above freezing today the house when I got home 11 hours later was still above 70 and there were enough coals to get a new fire going quickly (I discovered a new way of loading the firebox for ridiculously long burn times - not sure if it only works well when load time temps are teens or lower but that's when I've been doing it - basically I put large splits in a vertical orientation on the edge of the firebox which burn slowly as the middle load coals in the everburn action).
Everything that has been said about the long learning curve with this stove and the need for very well seasoned wood is true.
My only real big complaint/concern is the deteriorating rear (totally out of sight) refractory material that I and many others have noted. Until that issue is resolved I couldn't recommend the stove. Although technically that part of the stove is supposedly covered by the lifetime warranty for those that actually have a valid warranty.
tradergordo said:Sometimes those unsplit bucked logs seem dry, but they really aren't, which is why many only start counting seasoning time after its been split and stacked off the ground.
