CFM Vermont Castings Dutchwest Everburn Non-Cat Owners Discussion and Review Thread!
You will see, she will run like a champ!
Yeah, the chimney could never be too clean, when I clean the back of the refactory I always run the brush through the chimney.
That's interesting, what kind of flue and chimney setup do you have (length, bends, interior/exterior)? Ideally that everburn "roar" really SHOULD continue for a long time after you close the damper, that means it is efficiently burning the secondary gasses, although its not supposed to keep getting hotter and hotter when the primary air is closed (mine seems to stabilize around 600-650 degrees). What temps do you see and how are you measuring them? Have you examined and tested your door gaskets?
p.s. The removable polished brass handle sounds nice - you should sell them to Vermont Castings because almost anything would be better than their delicate ceramic handle! I wonder how many dealers get complaints from their customers about damaged handles? Have you made any custom handles for your own stove? I would love to see some pics! The problem with using any type of metal for a permanent handle is that it probably would get very hot unless you can figure out a good way to insulate, or us
e some kind of wire wrap like you see on other stoves.
[Hearth.com] CFM Vermont Castings Dutchwest Everburn Non-Cat Owners Discussion and Review Thread!
I found the perfect solution to the handle problem. I drilled through the centers of two wine bottle corks, the synthetic ones, and drilled a recess on the end of one cork to counter sink the head of the screw. It looks great, will not break, feels nice in your hand, and is a little larger than the original handle so you get a better grip. If there is a logo on the cork, just rub it briskly and it will come off, or just wait for time/use to wear it off. If you can find some with non-beveled edges they meet up better, no groove between the two corks. It can be tricky to drill the holes perfectly centered but I managed to do it freehand with no drill press. I've made them for three of my neighbours who also have Dutchwest stoves. Here's a picture.
Thanks to all for the helpful, interesting info! My 800 sf Adirondack house is fairly well insulated. Currently using Woodstock Soapstone Franklin Cottage DV- LP stove. I am considering these non-cat woodburners: DUTCHWEST 2477 (small); HEARTHSTONE Craftsbury; QUADRAFIRE Yosemite; HARMAN Oakleaf; LOPI Leyden. Seems all are made in the USA. ( I will use a RINNAI DV- LP as back-up & supplemental heater) . All things being equal, is it better to have a smaller stove buring 'stronger', or a larger stove burning a bit lower?... The sf space heating ranges listed in the brochures have a huge range. Like most everyone, I am looking for well built stove that is durable and works well ! Any advice will be appreciated. Thanks. -Mark Axen.
Reactions: Lemonbalm
800 sf Adirondack house is fairly well insulated. Currently using Woodstock Soapstone Franklin Cottage DV- LP stove. I am considering these non-cat woodburners...
I would choose a somewhat smaller stove burning 'stronger' over a much larger stove burning a bit lower - sometimes hard to get 'low'. Those are all fine stoves you listed... personally, I would go with a Woodstock Keystone cat for 800 sf.
You might want to start a fresh thread of your own, instead of piggy-backing on this one, to get more feedback.
This is an old thread and your needs and mentioned stoves are quite different. If you start a new thread you'll get better answers and attention to your specific needs.
I know this is an old thread started many many moons ago. I just wanted to thank everyone who has come in and given their experiences. Back in June I jumped on a Craigslist ad for a dw 2478. $425 was just to good to pass up for a stove that looked so elegant. I brought it home, cleaned her up and started googling how these new age epa burners worked. Well my first discovery was a thread here on hearth.com telling anyone considering a DW to run not walk in the other direction. My heart sank, did I really just shower away 400 plus dollars on a hunk of scrap metal? I had already removed our old Sierra pos and installed the"new" DW in its place so I told myself it was gonna be a do it die winter. Thanks to this thread and all the little tips and tricks revealed along the way, I'm happy to report I'm very pleased with our purchase. The stove has very good heat, I'm still getting used to different ways of loading for a decent over night burn. So far we have seen typical heat times of 5-6 hours before output starts to dwindle. and the house begins to cool. I also think it may be just a bit small for our 2000 sq ft but at present time the upstairs is not in use so we're have blocked it off with thermal curtains to keep heat down stairs. Here is a pic of the new girl in action.
Tony
  • [Hearth.com] CFM Vermont Castings Dutchwest Everburn Non-Cat Owners Discussion and Review Thread!
