TheFlame said:Todd said:mellow said:Todd said:There are a couple stainless steel cats on the market that are resistant to thermo shock and lite off at 380 degrees instead of 500.
Got any links for this? I am planning to replace the cats I have in my stove next season, I don't know how old they are, got them used off ebay.
I am noticing however that with the cat in my stove right over the fire it is very easy to get it to light off, but 380F would save even more wood.
(broken link removed to http://www.clearskiesunlimited.com/woodburningstoves.html)
http://www.condar.com/
Is that site right? Two combustors at $99 each required for a Woodstock Fireview? Woodstock only gets $125 I thought...
BeGreen said:Never heard of him! :coolsmirk:
Todd said:Chettt said:A new Kitty stove should come with at least 5 replacement catalysts. Has there ever been a first year burner that didn't run out of dry wood and have to burn green wood or garbage? If they threw in the replacements an owner would be fine for 20 years even if the manufacturer goes out of business.
I'm pretty sure all cats have at least a 6 year warrantee, where the 1st 3 years are free replacements and prorated after that. I had mine replaced free of charge after 1 year even though it was probably my fault. Cat technology is getting better. There are a couple stainless steel cats on the market that are resistant to thermo shock and lite off at 380 degrees instead of 500.
Highbeam said:Wet1 said:I didn't want to upset anyone by quoting prices over the forum (I don't know if that's a no-no or not). The price I got on the BKK was around $3130, the 91 was $1850... as I said before, quite a difference. The only thing I would really miss on the BKK is the thermostatic control.Highbeam said:What's the secret? Would be good for all of us to know the prices of all of these big cat stoves. The big BK, we know the woodstock price, the buck, the country flame.
I'm not shy, I spent 2049$ on my heritage after tax. Current hearthstone prices are available on Tom's site. They were actually cut just recently.
Thanks wet1. It really helps to put a figure to these stoves. Besides the thermostatic primary air the blower CFM is quite high on the BK compared to the 91 which doesn't specify. The countryflame was 600 CFM which is quite a lot.
The buck has a very difficult to remove catalyst package and 3 cats. They describe all sorts of penetrating oil and extra care in the manual. Much harder than the woodstock. The stove is tapered front to back to make it a better insert I'd guess. Looks funny freestanding.
The BK look is growing on me.
rumme said:I can only comment that I just installed a napolean 1900p non cat , dual burn system. Ive had it running for 5 days/ nights now, and its burning my wood so completely, that I still dont have 1" of ash covering the entire bottom of the stove floor. Before I go to bed, I put 3 logs in it, about 12" long, and in the morning, its ready to refire as needed on the glowing coals. So far im very happy for the $1400 price tag. I do not see me using my homes ineffcient electric heat pump to much in the future. If I save just $300 a yr in heating costs, the stove has payed for itself in less then 5 years and I dont have to worry about replacing cat converters.
It looks like it may take a month of solid burning, to create enough ash that mandates it to be cleaned out of the stove. I can live with that :}
That doesn't sound all that bad if it only has to be done every 6-9 years, but what about routine cleanings? I'm under the impression the cat(s) need to be brushed off every so often.Southland said:Highbeam said:Wet1 said:I didn't want to upset anyone by quoting prices over the forum (I don't know if that's a no-no or not). The price I got on the BKK was around $3130, the 91 was $1850... as I said before, quite a difference. The only thing I would really miss on the BKK is the thermostatic control.Highbeam said:What's the secret? Would be good for all of us to know the prices of all of these big cat stoves. The big BK, we know the woodstock price, the buck, the country flame.
I changed the cat in my parents Buck 91 over Christmas (the cat was 8 yrs old). It only has one cat unit, not three. It's not hard at all. You do need a deep socket in step 4. Here are directions cut from the owner's manual.
http://www.buckstove.com/buckfiles/manuals/Buck-Stove-Model-91-Manual-(Rev-10102008).pdf
CATALYST REPLACEMENT (Off-Season Replacement Recommended)
1. Spread a drop cloth in front of the stove.
2. Open the door and clean out any ash.
3. Using penetrating oil, generously lubricate the eight (8) bolt threads holding the catalyst housing in place.
Allow oil to penetrate.
4. Using a 9/16" wrench or 9/16" socket, loosen the eight (8) nuts and remove the catalyst housing (drop down)
and place in a suitable work area. BE CAREFUL removing the 8 nuts. If you break the bolt, you will have to
drill out the bolt (difficult) and wait for your dealer to order one! You do not want this to happen during the
cold weather!
5. Using needle nose pliers, grasp the front edge of the stainless steel “cans” which houses the catalytic element
and pull upward. Reposition pliers to another position and pull upward. Repeat procedure until the catalyst
can be removed from the housing.
6. Using a small putty knife or scraper, remove any gasket that may have adhered to the catalyst housing.
7. Now, obtain the new catalysts and wrap the stainless steel “can” with interam gasket and tape ends together
using scotch tape or masking tape. IMPORTANT: BEFORE STARTING TO REPLACE CATALYST,
contact your dealer and order the INTERAM gasket and the CATALYST HOUSING Gasket. Gaskets not
covered under warranty. It may take your dealer several days to receive the gaskets.
8. Insert the new catalysts into the catalytic housing and push down until they are seated on the top of the
stainless steel wire mesh supports.
9. Reinstall the catalyst housing into the stove and secure in place with the bolts.
10. The stove is now ready for use.
cold weather!
TheFlame said:The Fireview seems to be the ultimate in cat maintenance, does anybody know how bad the Keystone/Palladian is to maintain? I do know you have to go through the flue exit to get the cat out of them, but that's about it.
north of 60 said:rumme said:I can only comment that I just installed a napolean 1900p non cat , dual burn system. Ive had it running for 5 days/ nights now, and its burning my wood so completely, that I still dont have 1" of ash covering the entire bottom of the stove floor. Before I go to bed, I put 3 logs in it, about 12" long, and in the morning, its ready to refire as needed on the glowing coals. So far im very happy for the $1400 price tag. I do not see me using my homes ineffcient electric heat pump to much in the future. If I save just $300 a yr in heating costs, the stove has payed for itself in less then 5 years and I dont have to worry about replacing cat converters.
Are you not the one that posted this thread my friend. https://www.hearth.com/talk/threads/33585/ What you expected, and are looking for is actually what a new CAT stove will do. It will shut the fire down to a smolder. Sounded like you had more worries than replacing a CAT in that thread. :roll:
N of 60
N of 60
johnnywarm said:rumme said:I can only comment that I just installed a napolean 1900p non cat , dual burn system. Ive had it running for 5 days/ nights now, and its burning my wood so completely, that I still dont have 1" of ash covering the entire bottom of the stove floor. Before I go to bed, I put 3 logs in it, about 12" long, and in the morning, its ready to refire as needed on the glowing coals. So far im very happy for the $1400 price tag. I do not see me using my homes ineffcient electric heat pump to much in the future. If I save just $300 a yr in heating costs, the stove has payed for itself in less then 5 years and I dont have to worry about replacing cat converters.
Are you burning soft wood?
rumme said:north of 60 said:rumme said:I can only comment that I just installed a napolean 1900p non cat , dual burn system. Ive had it running for 5 days/ nights now, and its burning my wood so completely, that I still dont have 1" of ash covering the entire bottom of the stove floor. Before I go to bed, I put 3 logs in it, about 12" long, and in the morning, its ready to refire as needed on the glowing coals. So far im very happy for the $1400 price tag. I do not see me using my homes ineffcient electric heat pump to much in the future. If I save just $300 a yr in heating costs, the stove has payed for itself in less then 5 years and I dont have to worry about replacing cat converters.
N of 60
this moderator seems to disagree with you...heres their post on another thread..
If the flames could be completely stopped they would never be able to pass the EPA emissions test and therefore they could not sell the stoves. During the EPA testing the primary air control has to be closed completely down without smoldering the wood load.
Signature
Yeah, I know that wood stoves
bluefrier said:Rumme, that moderator was commenting on a non-cat epa stove. A CAT stove will burn the smoke from a smoldering fire.
rumme said:so this means that epa approved cat woodstoves allow the owner the ability to totally shut down the flames within a few minutes...via the air intake adjustment ...while epa approved double burn non cat stoves will not allow the user to totally shut down the flames at all via the same air intake adjustment ?
savageactor7 said:Also will it damage to CAT to continually run for max heat?
