As others have suggested, the meat thermometer would likely work well if you get the shaft parallel to the pipe and then wrap it with foam rubber, styrofoam sheeting, pipe insulation, wool socks, or whatever so that the the tip of the thermometer can see the water temperature after a minute or two.I'm willing to try about anything at this point. I have one very upset wife, since spending the amount of cash I have into this for it to not be heating our house.![]()
Would be better than what he has now but the chimney effect of the front panel assists the flow if there is adequate space below.Heck, in the meantime you can take the covers off of there to get things heated up
+1!Dont do it!
Forced Air isnt all its cracked up to be, at least not in my mind. Once you get your system dialed in, it should be perfectly comfortable for you. Baseboard needs airflow to work, cant get around that. Heck, in the meantime you can take the covers off of there to get things heated up (looks bad, should work OK). Just be careful not to mash any of the fins over by hitting it with anything. Worthwhile experiment at least to see if that helps.
Any suggestions on the newer digital read ones... like what is easy to use, and works good?
+1 ^^^He's likely bang on - but I don't agree with the air movement thing. The rads will make their own convection flow (when they aren't blocked at the bottom, that is) to get the heat circulating.
+1!
Just pull the covers off, relax, and plan your next move. Maybe have a tin-knocker make some new covers.
Seems unlikely. The covers are tight against the carpet now according to the OP. Removing the covers could not help but improve the situation.I doubt you will see much if any improvement with the covers off.
