kennyp2339
The best difference I give you between a cat vs non cat is the ability for the cat to burn efficiently over lower temps, An epa tube stove has to burn a higher temp to get the clean reburn, if you have the sq footage this is a non issue, I like to use the analogy of chasing the heat curve with a tube stove if your operating it properly, you load it up, you get good flames, it heats up, you reduce the in coming air down to minimize the flames but still keep secondary reburn going the stove top temps cruise between 550 and 650 deg, nothing to it, but the problem is your getting a lot of heat (btu's) at once, so the burn only really lasts between 6-8 hours then the fire goes into the coaling stage and heat is limited.
With a cat (using my bk as an example) I load it, it lights off and I set my desired temp (through the air stat) and walk away, as long as the cat temp stays active Ill have a clean burn, if I need more heat I turn the stat up. My burn times effectively range from 8hrs a load (when night temps are in the single digits or lower) to 24 hrs when temps are in the upper 40's / 50's, my heat curve is fairly flat in that sense because the stove regulates the air to the fire box, the cat combustor is what makes my heat due to its placement along the top of the stove.
As far as the Kuma sequoia - it has a natural convection deck that is made to ozz hot air away from the stove, but I still think you would need a blower to give it that little boost.
Also since you want to install this or any stove into an existing fireplace, I would pick the stove that's easiest to clean with out pulling it out of the fireplace all the time, and like others have said, plan for an insulated liner (Sequoia uses an 8" liner, maybe a limited factor for you) and a block off plate
