I've seen that all metal maul, think it's 15 pounds. The super splitter they call it, more like the back breaker. So far I haven't needed anything that big, thank goodness.
i dont think i could swing it for very longNoah said:I've seen that all metal maul, think it's 15 pounds. The super splitter they call it, more like the back breaker. So far I haven't needed anything that big, thank goodness.
smokinj said:i dont think i could swing it for very longNoah said:I've seen that all metal maul, think it's 15 pounds. The super splitter they call it, more like the back breaker. So far I haven't needed anything that big, thank goodness.
mayhem said:I'd say at least half of the members here have a splitter or rent one once or twice a year. The rest of us do it by hand either because we're cheap or we need the exercise.
Check out the gear room for splitter threads daily!
cmonSTART said:Nice splitter. What model is that? I have the TW-P1 myself and I LOVE it. They are very very well made machines.
That looks just like mine. I better go check my garage. JeffNoah said:My splitter, not sure the tonnage though.
ScottF said:33 ton . It seems like you wouldnt need one that strong. Can you crosscut with it also if you sharpen the wedge? I would think it would crush right through
SlyFerret said:I've been borrowing my neighbors splitter when I need it, but would really like to have my own.
I've been eying the "big one" over at TSC, but it's going to take me a while to save up for that.
-SF
karl said:Ok, In the size does matter department. How big of a splitter do you need? I have a 5 ton electric. It's pretty good, but I can stall it out easily.
How big does one need to be to go through anything?
Mine splitts for example, ave.50in rounds 27 ton will do it but i am working to death!woodconvert said:karl said:Ok, In the size does matter department. How big of a splitter do you need? I have a 5 ton electric. It's pretty good, but I can stall it out easily.
It all depends on what you forsee getting into. If you cut off of a stack of stick wood...a 20ton-er is more than enough. If you are cutting interior wood lot trees that are straight with minimal snottyness, the 20ton-er is more than enough. If you get into some fugly hedge row stuff that goes up 10ft and is a clusterfluck of branches....you'll prolly still be ok but there will probably be some you won't be able to split. I do get into quite a few of those hedge row trees and they are a mess of knots so I went big ( I also get a truck load of sticks every three years which it splits without sweating). It all comes down to what you typically split or what you think you may split down the road, though, it's hard to predict. I'm the kind of guy that will go bigger than I need at the moment for what may come down the path later on. I'd say a 20ton splitter will do most of what you need though.
LEES WOOD-CO said:woodconvert said:karl said:Ok, In the size does matter department. How big of a splitter do you need? I have a 5 ton electric. It's pretty good, but I can stall it out easily.
My grandfather always said "build it BIGGER, you can always grow into it". Over the years I have done just that.
I like your thinking.
woodconvert said:LEES WOOD-CO said:woodconvert said:karl said:Ok, In the size does matter department. How big of a splitter do you need? I have a 5 ton electric. It's pretty good, but I can stall it out easily.
Thanks Lee. That line of thinking has worked out well for me over the years for varius things. Not sure that it would be the optimal method for choosing a wife/girlfriend though ;-P
