That's a signficant difference. "Premium" medium- weight is supposed to be a "lifetime" product, does that mean they expect the kind of people who get it will be living their houses for 25% less years?I would say 20 to 25% shorter
Lifetime means the lifetime they assign to that product. Not your lifetime. Read the fine print. Now some Olympia products have a forever warranty. But only if you have it installed and serviced every year by a pro etc.That's a signficant difference. "Premium" medium- weight is supposed to be a "lifetime" product, does that mean they expect the kind of people who get it will be living their houses for 25% less years?
Good point about CAT being overactive in the beginning, and I was wondering about top-down versus bottom-up lighting. In our old open fireplace and the old outdoor stove, where we burn poor wood that's not dry, it seems bottom up is the only way to get started.Your cat will be "over-active" the first few months. That's normal.
The thermostat should prevent overfiring (as long as you keep the door closed and the bypass closed when the cat is active).
The cold air in the beginning is no problem. Unless you get smoke in while starting up. If so, use a propane torch for a few minutes, blowing hot air up the bypass opening.
Just make gradually bigger fires. Preferably without feeding a piece by piece. Just ligth top-down fires on progressively bigger piles of wood.
Play with it, observe, sit by it. This'll make you learn how it behaves and give you confidence.
Pic of first fire?
I haven't noticed much paint odor, yet. I opened the basement doors and windows and set up fans in the beginning, expecting it to be bad, but now I closed everything up.You’ll wanna burn it hot to bake the paint smell off..
The top down is good for the environment and I like it for lighting full loads. But for the initial fires I was mentioning it because I thought you were opening often to load more and more pieces to scale up the fire. Instead, I'd make a fire and let it burn out. Then make a larger fire and let it burn out. Rather than paper+kindling, burn a bit, add a few wrist sized pieces, burn a bit, add more etc.Good point about CAT being overactive in the beginning, and I was wondering about top-down versus bottom-up lighting. In our old open fireplace and the old outdoor stove, where we burn poor wood that's not dry, it seems bottom up is the only way to get started.
Yes the stove is real hot now and 'm smelling it more. I don't want the windows and doors open all night, and besides that might affect the thermostat bringing in all that cold air.The top down is good for the environment and I like it for lighting full loads. But for the initial fires I was mentioning it because I thought you were opening often to load more and more pieces to scale up the fire. Instead, I'd make a fire and let it burn out. Then make a larger fire and let it burn out. Rather than paper+kindling, burn a bit, add a few wrist sized pieces, burn a bit, add more etc.
Just makes life easier.
Progressively larger. Until you reach a full firebox. Once you reach a high enough temperature, you'll smell the stove. You may not have reached that yet (large stove, much to warm up).
That's very good news. The basement temperature has been slowly rising, up to about 60 degrees now. The cat thermometer has finally dropped back to about halfway, within the white area.I'd fire up the stove during the day when you are around for the windows. (And the mildest day...)
The cold air shouldn't affect the Tstat, unless it's directly aimed at it. The Tstat is measuring the temp of the stove, not the temp of the room.
The cat gauge will be at or over the max for a while. That's normal for new cats. Nothing to worry about.
Every install is different. On mine on a cold start: I open it all up then warm the flue for 10-20 seconds with my torch. add 3 -5 peices of wood. Start it with 1/4 super cedar. Let it burn till the cat is active. Then close the bypass and shut the thermostat all the way.I've been watching the cat thermometer, now it's all the way up, at the very end of the white, active area of the dial on the edge of the last, black area. What does that mean? I'm worried that it's getting too hot. I turned the thermostat in the rear back even more, slightly before the white stripe begins. How far can I turn it back?
I shouldn't open the door now when it's very hot because that could damage the cat by sudden temperature drop.
Update on the installation. I have been able to meet all clearances (though I had doubted) and the stove is performing perfectly.Venting is not part of the clearances safety test established at the time the unit was tested.
As I commented last week: https://www.hearth.com/talk/threads/blaze-king-install-puzzle.190556/page-2#post-2559569 "I don't think I have no dealer support. I do trust them, and try to put myself in their business shoes and see how hard it is for dealers to find and keep professional installers, provide or arrange secondary shipping to a customer, and know all the answers to technical questions...."Venting is not part of the clearances safety test established at the time the unit was tested.
I'm not sure what you mean by a drop down.Can you post a pic?
Did you say a drop *down*? If so, be aware that draft will be significantly affected. It may do well now. But if it get warmer outside, you may have issues.
Sadly, I needed to add about four inches of horizontal and then a 90 degree down
What is the reason for raking the coals forward when adding logs? My inclination is not to move things around because more ash rises up on the cat surface unnecessarily (even though the bypass is open) and instead wait until the fire is out for a slow and gentle shoveling.Every install is different. On mine on a cold start: I open it all up then warm the flue for 10-20 seconds with my torch. add 3 -5 peices of wood. Start it with 1/4 super cedar. Let it burn till the cat is active. Then close the bypass and shut the thermostat all the way.
If the room is cold I kick the fan on for an hour. If not then it just runs as is for the next 7 hours or so.
On a restart when im adding wood to a warm stove: Open it all up. Rake the coals forwards. add 3 - 5 pieces of wood. Let burn till cats active or 5 minutes, which ever is longer. Flip the bypass closed and turn it all the way down. Come back 8-12 hours later.
Yes, the last fitting before the vertical going down into the stove is a 90.That is what you said
Maybe you are describing while going "in" towards the stove rather than describing the pipe in the direction that the gases flow?
I agree.Because BKVP is here providing input and answers speaks highly of the stoves IMO.
Also, I've been adding more than 3 to 5 pieces, making it about 3/4 full, I think. I let it warm up with the bypass open then close it in ten minutes or so if the CAT is active. I don't really understand the temperature setting knob. There is a white band, and a black area before that. I've been setting it at the very beginning (narrow tip) of the white band, but I'm wondering: how far back before the white band begins can it be set and how will it function?
6" to a masonry surface is not a safety issue, rather performance based. The OP' rear wall could reflect heat back to the thermostat and not allow it to perform as designed.Does your manual actually require 6” to a concrete wall in the rear or is it a “clearance to combustible”? There’s a difference.
If not prohibited by the manual due to rear clearances, I would prefer not to have the additional 90 and horizontal section on your relatively short chimney. As I recall you only have a 16’ stack and two 45s subtract from that to make your stack less than the required 15’ minimum.
Which is a worse performance issue? Underheight flue or less than 6” to masonry? Honest question.6" to a masonry surface is not a safety issue, rather performance based. The OP' rear wall could reflect heat back to the thermostat and not allow it to perform as designed.
Both.Which is a worse performance issue? Underheight flue or less than 6” to masonry? Honest question.
