You know, you've heard in writing from the owner of the company to not install their stove. That is end of story. Plus, it sounds like you have no dealer support now. Since you purchased the stove the price has gone up a lot. Sell it while the market is strong. You may even be able to make a profit. Also, the advantage of the King is low and slow-burning. It sounds like you are going to need the opposite, that is high output heat in order to overcome the losses due to the uninsulated basement and air leakage. At that point there is greater advantage to installing a stove with much higher output potential. This is one of the reasons why we don't have a BK stove. There are other very good stoves to use as an alternative. Take a look at the big Regency F5200 as an alternative. It provides a lot more top-end heat.
I'd like to hear about any stoves that are better than BK, but realize it's not necessary to sell this stove (I'm the worst salesman, giving everything away) because this BK could be moved to the other, smaller building that also needs a stove, where a pipe could go straight up through a hole cut in the roof, and there is over 8 foot ceiling height so I could easily use this tall pedestal.
I've done more measuring since I talked to someone, actually not just one, but two technical people, at BK the other day. Based on my conversations then, and even at the beginning of this thread yesterday, I suppose it did sound impossible. But now I think it can be done by: (1) turning the wall-connecting 45 angle sideways, instead of down at the wall, which would produce a very short 6 inch horizontal, followed by a 90 degree instead of a 45 down into the vertical stovepipe, which would (2) move the thermostatic control box in the rear from 4 inches to 10 inches from the wall, which is 4 inches more than the required minimum, and it would also (3) barely meet the 2 foot minimum vertical stovepipe rise requirement, but only IF I have the shorter BK base, instead of this high one that I got.
I don't think I have no dealer support now. I do trust them and try to put myself in their business shoes and see how hard it is for dealers to find and keep professional installers, and provide or arrange secondary shipping to a customer, and know all the answers to technical questions, or even have time to find the answers, when they are selling high volume of all kinds of heating appliances of all different brands.
But now I discovered this forum where I can be in touch with people who have experience with everything, and have good answers. Thanks to all of you for responding and I learned a lot, especially for being tipped off that I have the wrong base, which was the most obvious but never dawned on me.
Everything works out for the best in the long run, and I'll keep you posted when it does. And yes, I've given up on the idea of using it without a base, or with a non-BK base. Aside from pure curiosity, I don't need to know anymore how it might perform without a base, which was my main thrust in starting this thread.
