3fordasho said:Todd said:It's very easy to top 1000 degree internal stove pipe temps with the Fireview in bypass mode because the bypass is located in the back of the stove and directs the flame right up the pipe. I've been over 1500 on occasion. The best thing to do on reloads is to keep your air at #2 or less, you don't need all that air and you will waste a lot of heat up the flue. The only time I run wide open is during a cold start up. It sounds like you need a higher rated thermometer, my Condar probe goes up to 2000.
Exactly, this might be a case somewhat unique to the fireview and some other cat stoves with the bypass. I've seen the results of air being left wide open for maybe 5-10 minutes too long, what would happen in the worse case where someone loaded the stove and then forgot and went to bed or left the house? somethings going to melt down. I know the easy answer is the stove operator should be aware and never let this situation occur, but human nature what it is....
Don't open your air all the way when reloading.
A better invention would be an automatic woodbox reloader... <-------I'd be the first one to buy one!!
