Thanks for the reply wjohn, I don't think i was clear about I found with the probe on my stove. Previously I didn't even know about the probe until your posts and then your pointing it out on the parts list, but I was aware of the lower damper that the chain from the probe attaches to, I just didn't realize a temp probe assembly ran the damper via the chain. It was all a mystery to me and the stove ran fine until it plugged up because of the blanket getting sucked up into the stack.
Anyways, when my problems started I always wondered why the lower damper was always closed and the chain slack . My air intake on the stove is wide open to the shop, it just sucks up shop air when it needs it. I am able to get my hand/finger into the intake and check the damper position. Prior to cleaning the probe it seemed like the damper was always closed and I always had to crack the door open to get the stove going.
Now after I cleaned the probe, when the stove is at room temp the damper is held up and wide open and the chain is tight. I can manually push the damper closed with my finger and it is pulled back open when I release my finger, so that tells me the probe assembly is working like it should.
I think the probe assembly got so gunked up from the blanket issue that it was gunked up enough that it couldn't open/close the damper, it was just stuck closed. Once I cleaned it, now it seems to function properly for opening/closing the damper. Last night before I lit the stove off the chain was tight and the damper wide open. Once the stove was up to temp the damper was closed and the chain slack. I went out this morning and checked the stove and it was cool and at room temp, the damper was wide open and the chain tight. So I think the probe assembly was gunked up enough to prevent proper damper control. I think the temp part of the probe was fine, just the mechanical operation of it was messed up.
At least that's my theory! I am no stove expert by any means, but I am learning. Correct me if I am wrong in my understanding.
The 2 times I have lit the stove after cleaning the probe assembly the stove has just worked wonderfully. Last night I didn't even have to leave the door cracked to get it going. It came up to temp quickly and maintained the sweet spot on the stack temp indicator and the stove settled out around the 550 degree mark. I am just heating my shop with the stove so I usually only lite it off in the evenings for a few hours just to keep the shop above 50 degrees overnight and through the next day. I can quickly bring the shop up to 65-70 degrees (its only a 22x24 shop and its well insulated) unless its 40 below outside and blowing 50mph, then it takes longer of course.
So if I understand the stove operation correctly, the temp probe opens the damper wide open when the stove is at room temp and slowly closes it when as the stove comes up to temp. Once the stove is at operating temp and the damper closed, what controls how much air the stove gets? That's where I am still confused.
Again thanks for the info and help, I appreciate it!
![[Hearth.com] Aspen C3 Baffle Replacement [Hearth.com] Aspen C3 Baffle Replacement](https://www.hearth.com/talk/data/attachments/317/317936-9ce72dffda2aa62ee35b1e388644e130.jpg?hash=EQjw6Q4gFh)
