Hi folks, I am beginning to REALLY hate my Ashford 30. No matter how I burn, stack, or run the stove, I get creosote on the glass which is so hard I have to use a blunt scraper to get it off with much difficulty.
I have spoken to the installers a number of times; called the tech line at Blaze King, but to no avail. My wood is well seasoned, dry fir or pine. The only way I can reduce the build up of creosote it to run the unit hotter more often but that only helps a bit. The house gets way to hot if I run it like that.
In my opinion as a seasoned engineer, and having worked at FPI (Regency Fireplaces), I can only come up with the conclusion that there is inadequate air flowing down to the glass door to keep it clean. A better choice would have been to design it with a lower up draft of air over the glass into the cat.
The install flu is going out into a framed chimney chase with 2 - 45degree sections and a 15ft rise. Moisture content as low as 8 - 10%, seasoned up to 6 years unders shelter.
Any opinions or ideas would be fantastic. Also if I an right in my assumption of the draft, is there a safe way to modify the air flow without messing up the cat action?
![[Hearth.com] "Dirty" Blaze King windows [Hearth.com] "Dirty" Blaze King windows](https://www.hearth.com/talk/data/attachments/188/188103-00e1e2e99f64754167ed7e7a6b1b4365.jpg?hash=YW_YmeR9G-)
![[Hearth.com] "Dirty" Blaze King windows [Hearth.com] "Dirty" Blaze King windows](https://www.hearth.com/talk/data/attachments/188/188104-b30f7a1816dfe7e032f3642cdf34306e.jpg?hash=BzBQwHPM0a)
