I'd say these 3 stoves are quite similar in heating capabilities.. Based on this I'd go with which look you prefer. I can tell you that you can sit near the T-5 and not feel cooked because the cast iron sides have an air space between the firebox and the cast iron so the cast iron always stays under 300 degrees. Add a blower to keep the heat more uniform and they help alot in colder weather.. The T-5 blower is fairly quiet as blowers go and I can't speak to the F55.. I heat 1600+ sq. ft. in SE Mass. with the T-5 and it heats my home very well..differences between the PE Alderlea T5/6 and the Jotul F55 for our desired needs.
I just looked at our plan again and we'll be just over 1,200 sq. ft. on the main level and another 700 up. I plan to have a look at the new Carabassett by Jotul in the next few days, looking forward to bringing a tape measure and check out the interior dimensions. The Jotul appears to be 15% or less expensive than the PET5. I'm getting a quote of $2,495.00 for the T5. Seems a bit high.I'd say these 3 stoves are quite similar in heating capabilities.. Based on this I'd go with which look you prefer. I can tell you that you can sit near the T-5 and not feel cooked because the cast iron sides have an air space between the firebox and the cast iron so the cast iron always stays under 300 degrees. Add a blower to keep the heat more uniform and they help alot in colder weather.. The T-5 blower is fairly quiet as blowers go and I can't speak to the F55.. I heat 1600+ sq. ft. in SE Mass. with the T-5 and it heats my home very well..
Good Luck!
Ray
That is a big stove! Does that MSRP include the cast iron skin? If so that's a decent price.. Ash pans are something I don't care about and don't use on my T5..
I've got a PE Neo 1.6 and the ash pan and the stoves ash lip are useless.Excellent firebox though.
Ray
I have run the F55 for a couple weeks now...sold my Oslo. Like that I can load EW and NS. I'd say the claimed firebox volume is pretty accurate...loading NS I can cram almost 2.5 cu ft (16" splits) on top of a coal bed (~2 cu ft EW). I too have a strong draft and the secondaries have gotten away from me a couple times while burning NS with the air control shut down at ~300* stove top (stove top temps hit 650*-700* for a good hour plus until secondaries started to slow down)...still seeing if I can get better control by shutting down the air sooner to avoid off gassing the whole load at once...possibly a different mix of wood (some of my wood is maybe too dry ~12% moisture). This has not really been a problem though as the outside temps on these nights (in the low teens and upper single digits) warranted the extra heat and the burn time was not significantly affected. It would be nice if the firebox was completely square (as previously mentioned the back firebrick protrudes ~1" into the firebox on each side making the back 4-5" of the firebox ~2" narrower than the front). Loading NS and EW I have not had a problem keeping ~1900 sq ft of my house (built 1980 with average ceiling height ~11-12 ft., somewhere between tight and drafty) toasty on 2 loads/day (ash/maple/cherry/other mixed hardwoods). I get about 8 hours useable heat (stove top >/= 300*) and have no problem starting from coals up to 12 hours later. A few nights ago (with temps in the low teens) I loaded up NS at 8pm with the stove room at 71* (upstairs bedrooms 67* - 70*), was cruising at 500* by 9pm...when I got up at 6am the room temp was 69* (bedrooms ranged from 62*-67*), stove top was ~200 and there were plenty of hot coals to throw in a full load and have her cruising by 7am. I think with a little more time with the stove (possibly a damper to reduce the draft on those really cold nights) this stove will be everything I dreamed it would be...for the price I don't think I could be happier!
I have been running an F55 since October. I do not think the stove is as large as some perceive it to be. Measured from fire brick to fire brick it is 20 in wide. Measured from firebrick to doghouse air is 18 in. the baffle is tapered up from back to front and at the lowest point it is about 11 in. There are also two protruding firebricks in the back that I will try to get pictures of for you. Using these measurements I get about 2.25 sq ft. I am measuring this relatively conservatively. Should I be measuring to the glass, and also should I include the extra under the tapered baffle? I am heating a two story 1600 sf house in southern Wisconsin. My conservative nature even got the best of me and I decided not to open the door to the upstairs. Don't get me wrong this stove would probably heat a 2000 plus home if ran 24/7. I usually just run the stove once a day when I get home from work. I am happy as I have only used just shy ofa face cord so far. The stove did require some modifying of the secondary air due to strong draft issues. Any particular questions feel free to ask.
A couple more questions in addition to the good ones by saydinli. Has the stove always behaved this way or is it better once it gets very cold outside. Can you describe the flue setup in detail, starting at the stove and all the way up to the chimney cap?We had an F55 installed 2 years ago and we are having problems with smoke escaping into the room when we add wood. To start the stove we have to open a window and leave the stove door cracked a bit or the flame will go out after the paper burns. I installed an outdoor air feed system and the problem still exists, any ideas.
24” up from the stove to a 45, 21” to another 45 and straight up the chimney. The stove has always behaved this way no matter of the outside temperatureA couple more questions in addition to the good ones by saydinli. Has the stove always behaved this way or is it better once it gets very cold outside. Can you describe the flue setup in detail, starting at the stove and all the way up to the chimney cap?
the chimney is 6', 2' above the peak of the house. We have a single level house so most of the most of the chimney is outside.How tall is your chimney? Is most of it on the outside ? Where is your stove located ? Is it in the basement or on the main level?
It is a little over 6’ from the thimble to the top, it’s an insulated stainless chimneyAbout how high is it from the thimble to the top of the chimney? Does the chimney have a 6" stainless liner in it or is it just a clay liner? If just a clay liner, what are the approximate inside dimensions?
Thank you so much for this, I do have another smaller stove in our garage so I will switch them out, the chimney in the garage is over 14 feet so it should be toasty in there this winter.You have done the right steps on the interior and the insulated liner is great, but it seems like there is too little total flue system height on the stove for it to draft well. Most modern stoves need stronger draft. The F55 wants about 15' total. If possible, it sounds like the chimney need an extension. In lieu of that it may take a change the stove to one that can work ok with a shorter flue system.
From the F55 manual:
"Chimneys shorter than 14 feet (4.27 m) may not provide adequate draft. Inadequate draft can result in smoke spillage when loading the stove, or when the door is open. Poor draft can also cause back puffing (ignition of gas build-up inside the firebox) and sluggish performance. The minimum height does not, in itself, guarantee proper chimney performance. Optimum draft force should be in the .05 - .10 in. w.c. range measured by a Magnahelic gauge. Draft at .07 w.c. is ideal."
Instead of the hassle of moving the stove I added a 3’ extension and brace outside. Even though it is a rainy day here we can see the difference, we can open the door without any smoke coming back into the house. The chimney is now about 16’, I only wish I would have thought of seeking advice here when we installed this unit. Going to be a toasty winter here, thank you again.Thank you so much for this, I do have another smaller stove in our garage so I will switch them out, the chimney in the garage is over 14 feet so it should be toasty in there this winter.
