That’s the thing. I could remove a few big scoops daily if they included the roughly 1/2 of which are coals. Sifting out and reburning the coals I could stretch that to three days. By day four the ash bed is approaching maybe 2” deep across the entire bottom of the stove and I need to push it away from the front lip. I thought that area needed to be clear for air? — air wash for the window maybe?How often are you removing ash?
My pine doesn’t leave a lot of ash. If burn 24/7 I could go about 3-4 weeks. (I always get
Temps warm enough that I won’t have any coals.
I guess its called a hoe or I would have called it a rake even though, I suppose it’s more hoe’ish. It’s part of the set I have. I guess it is a hoe since it’s the one I use the most.30WCF, What tool are you using? Is that a hoe? I find my coals buried in the morning so my shovel doesn't easily take them from the top. Someone mentioned using a poker and that's been working well in place of my trying to actually sift out the coals using a sifter. I'm surprised you find your ashes disappear!?? What kind of stove do you have? My Green Mountain 60 hybrid creates a lot of ash. I exclusively burn pine and have hot fires (so I think). I don't have an ash grate or anything, but could easily get a few big scoops mixed with coals each morning, or a few big scoops of just ash every few days if I'm able to reburn the coals. The Green Mountain doesn't have a deep entry for ash to lay so maybe it just feels more in the way than your stove's design?
May I ask what you use the ashes for in the spring?
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323835-871e1953a5f5ef44164df6772eec9375.jpg?hash=Pq2C0Ehnxi)
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323839-61c8201fdcbac46b25b75c462c5905bc.jpg?hash=JarUiXyF2c)
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323840-a8f5f0f797323872e72eafb6d13cd8c6.jpg?hash=p_Gg9N9LiZ)
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323837-2af615a94362f204809e26a940c13dfa.jpg?hash=dnImPqL4Eq)
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323836-68e8858e691194e1d63aae28fd98d07c.jpg?hash=hiXzWAyuqP)
![[Hearth.com] Any tips to cleanly raise coals above the ashes? [Hearth.com] Any tips to cleanly raise coals above the ashes?](https://www.hearth.com/talk/data/attachments/323/323841-48cbc3e321bd2844fd9a116e4c85be4b.jpg?hash=7ZH6-UgDae)
This is news to me. I've always assumed hardwood burned hotter than Pine?! When you say "small splits" do you simply mean like taking a normal firewood log and splitting into two or three smaller pieces lengthwise? What did you mean by 'mention of bark'?But at others here have enlightened me, some pine or small splits, I see mention of bark, will kill those coals fast. In my experience, in the process it consumes the majority of my ashes as well.
Hardwood has more BTU content typically, but that's different from the rate of combustion. A 2" split of pine will combust and give up its heat faster than a 2" oak split, so it could be considered a more 'peaky' fuel. An oak fire will provide more BTU/hr than the pine.This is news to me. I've always assumed hardwood burned hotter than Pine?!
Oh wow, I need to find some other posts discussing this. thanksHardwood has more BTU content typically, but that's different from the rate of combustion. A 2" split of pine will combust and give up its heat faster than a 2" oak split, so it could be considered a more 'peaky' fuel. An oak fire will provide more BTU/hr than the pine.
www.hearth.com
Yes. A couple smaller splits will burn faster and hotter than large splits burning down coals and eating ashes.This is news to me. I've always assumed hardwood burned hotter than Pine?! When you say "small splits" do you simply mean like taking a normal firewood log and splitting into two or three smaller pieces lengthwise? What did you mean by 'mention of bark'?
Your stove might be shut down too long to not let the coals burn, but I’m also not adding a full load on top of coals. I’m putting a few pieces and lots of air and surface area to make the coals and ashes disappear.My pine has the bark on it. My stove has a secondary burner and a catalytic burner (is that what they mean by tertiary combustion?). It's lined with Soapstone.
Yep. Just a split or two to burn them off.I recently read softwoods are best for rocket stoves or gasifiers that then burn the wood gas. But sounds like others here and yourself seem to get hot enough burns to burn off hardwood coals here?
Not dry enough, choked down too tight too long, or packing a full stove on coals and turning the air down again instead of burning the coals off with a small “airy” load.In any event, I exclusively burn pine and get tons of coals and ash. Maybe my wood isn't as dry as I thought?
I don’t know… a firebox full of regular sized oak certainly packs more btu than a regular sized firebox full of pine, but I can drop a full firebox full of pine pretty quickly. I could probably get 3 full loads of pine consumed before a load of oak is. Would that push more btus into the house? *shrug* maybe? I know I’d want that dense load of oak at night so I wouldn’t be getting up so often to refill the stove!Hardwood has more BTU content typically, but that's different from the rate of combustion. A 2" split of pine will combust and give up its heat faster than a 2" oak split, so it could be considered a more 'peaky' fuel. An oak fire will provide more BTU/hr than the pine.
That's me. Bark is a free BTU injection that also gets rid of your scraps and burns down the coals, it's perfect for the job.I think it’s @Caw that burns the hardwood bark that falls off his splits to burn down the coals. A couple handfuls of bark is like jet fuel too.
I probably burn at about the same frequency as you do. I’ve had the A/C on the last two days. Probably be on tomorrow, then, 28 on Monday 🤷♂️. But to answer the queation. I’d say 3-4 weeks between scooping ashes if I manage the coals by burning them off. If I didn’t burn them off, it would be daily.How often are you removing ash?
Mines not a cat stove, and I don’t have as many control options. Don’t be so hard on yourself for having coals left in the morning after shutting it down for an overnight burn. Rake them to the top. If you pile up dehabilitating coals like I do when I’m burning straight oak, the try some loose loads that burn hot and fast.Every morning I wake up with tons of coals buried under ash. I leave the air intake open 1/4" in the medium-low burn rate as the manual states.
I use the poker as well. Other than that I only use an ash shovel.Generally I just use a fireplace poker, I use the scooper when I try to clean ash but want to keep coals
I dump some of them in my garden, sprinkle some around my fruit trees, and then sift the rest through hardware cloth and spread them with my fertilizer spreader on my lawn. You want to do the latter on a calm day.30WCF, What tool are you using? Is that a hoe? I find my coals buried in the morning so my shovel doesn't easily take them from the top. Someone mentioned using a poker and that's been working well in place of my trying to actually sift out the coals using a sifter. I'm surprised you find your ashes disappear!?? What kind of stove do you have? My Green Mountain 60 hybrid creates a lot of ash. I exclusively burn pine and have hot fires (so I think). I don't have an ash grate or anything, but could easily get a few big scoops mixed with coals each morning, or a few big scoops of just ash every few days if I'm able to reburn the coals. The Green Mountain doesn't have a deep entry for ash to lay so maybe it just feels more in the way than your stove's design?
