Sorry, I'm afraid this may be a dumb question, as the obvious answer is "sift them out".
I have a Green Mountain 60 burning exclusively pine, and half of it still has 15+% moisture, regardless I don't think it's much better with the wood I knew had 5%. (I've only had the stove 1.5 years and it's been a challenge retrieving wood from my steep backyard to properly season. I will be borrowing my friends ATV early next summer to finally have a proper seasoning.)
Every morning I wake up with tons of coals buried under ash. I leave the air intake open 1/4" in the medium-low burn rate as the manual states "is the typical setting and is preferable if the stove is unattended.At this burn rate, a little goes a long way." On very rare occasions I'll notice somehow the was a more complete burn. Maybe this is due to the Catalytic nature of the stove?
User begreen recommended this scooper which I got but I've noticed the wires are far too close together. I've been using a wire rack for a toaster oven which has much wider spacing, but even that creates a giant mess if I attempt to shake it to allow ash to fall through. I do this within the firebox itself but the plume comes out.
Does a rake work better for some reason?
