Mt Bob
The burned trace on that board can be repaired,with a trace repair kit,or by using small wire.Older PC repair places have the stuff,and,lots of ham radio people could do it for you.
The inside of a cartridge heater is a wire wound element.If it is loose from the epoxy inside,it can cause a short when hot.
This is a long shot but possible that you un-luckly got 2 bad ignitors.....
I doubt it but not impossible....
if you use some solid telephone wire with just the tips tinned you can fix that easy. clean everything good and flux is your friend. after it is soldered use a q tip and isopropyl alchohol and clean the area of flux. then I coat the connections with clear fingernail polish. put an in line fuse to the igniter only way to make sure it dont happen again
CorrectWell, If I check them both tomorrow with a 110v test circuit, I should find out, shouldn’t I?
I’ll take a look at it tomorrow,,,,not sure about my soldering ability,
Does it make a difference which of the two wires I put the inline fuse in?
Shouldn't matter at all. Just connect to the other connectors. My igniters always came with the connecting clipsFinally going to get back to my Quadrafire,,,lost a lot of time last week dealing with cellular problems,,,some times AT& T makes me crazy, but they are the only carrier we can get.
Anyway,, the new igniter came with those stand plastic covered slip in connectors,,,, can I just put the matching connectors on the other wires,,,,,or is there some reason I need to use the old fashioned way with the ceramic wire nuts???
Don’t forget the in line fuse
That sounds good... let us know..Unbelievable....We actually have a Radio Shack dealer, of sorts, in our village...The lady there, showed me a choice of 3A fast blow fuses and holders,,,,better than I could find online....so now I’m set with that......a nice inline fuse holder.. And then to top if off she thinks the owner should be able to repair my circuit board...
