Good morning, I will keep this super short, you Are interesting? Green Wood, specifically locust. Have you ever heard of lava rocks being used in a wood stove? I bought a stove from a guy that uses lava rocks in the design above the combustion chamber. all the heat rises up as with the smoke, through the lava rocks hence heating them up, catching, absorbing the creosote. What i have found is that this lava area above the fire keeps a tremendous amount of the heat in the stove and does not let it out the flue. This guy can put toliet paper over the flue, without it catching fire. So i guess that this kinda sandwiches the heat between the upper lava rock area, and the coal bed. this requires less air to fuel ratio and a more efficient burn. I have placed seasoned wood in, and it burns up faster. do to the sandwich effect. Water, has the second highest heat carrying capacity, other than amonia. it will smoke for the first fifteen minutes, until the out side of the log is scorched then no smoke the lava rocks help, tremendously. After the outside of the log is burnt, the interior of the log still has moisture, gives me the longer burn. If there is no smoke, then there should be no creosote correct? I pulled my flue apart acouple of weeks ago, the only thing I found in there was fluffy carbon, scraped some off and took it to the incubator that I have been working with. I can tap on the pipe and it falls off. Hmmmm. I'm ready, no fear, with no disrespect. Lava rocks capture the particulates. and hold the heat in the stove. AlexWelcome to the forum Alex
I can understand your fondness for locust but certainly can not understand a fondness for burning green wood. Either you've heard too many old wives tales or listened to some extremely bad advice. But I can believe it because I've heard that same bunch of baloney many times myself.
For a little background on myself, we've burned wood for a few years now and fortunately I also grew up in a wood burning home. In fact, we were one of a very few folks we knew who burned dry wood. Most folks back then cut the wood in the fall and even into the winter and burned it right away. They knew nothing about how wood should be handled and burned. Sadly, there are many yet today and your post shows that you are one! Please do not think I'm attempting to run you down or put you down at all because that is not my intent. Hopefully though, we can reason things out a bit.
The first thing that happens when you put wood in the stove is that it has to get rid of the moisture. It has to evaporate and that goes up your chimney. When the chimney is a bit cool, that wet stuff creates lots of creosote. Of course this is a bit simplified but you know what we're talking about.
Typically, folks will state that the wood is a bit harder to get going and you have to give it more air. You say it cranks out the heat. It can give you some heat but the trouble is, there is probably as much heat going up the chimney as there is staying in the house. This means you will burn up to twice as much wood for the same amount of heat. I really try to not be lazy but at the same time, I don't like to work harder than is required, so that is a good reason we let our wood dry before burning it.
One winter we ended up in a bad way. I had been injured and, of course, could not cut any wood. So naturally we ran out of wood and ran out before I could get back to cutting. But I knew a fellow who cut a lot of wood and sold a lot. We've known each other for 60 years or more and I figured I could get some good wood from him. Wrong!
The first load he brought I about crapped myself. It had been cut that morning and split then delivered; all in the same day. Naturally I was a bit ticked but my hands were tied. Fortunately we got a really good price on the wood. But gee whiz. This was white ash and, as most folks know (that should be, they think they know), ash can be cut and burned right away. That is what makes ash so great! Right? Wrong!
Ash indeed is one of the lowest moisture content woods there are when cut. Still, it will be about 35% moisture when cut. That is way too much water to attempt to burn. But, we burned it all that winter. We did not freeze nor did our water lines freeze. But we were never warm that winter either. In addition, we cleaned our chimney many, many times that winter. We fought the fire constantly but learned to load the wood on a huge bed of coals. Let the coals burn down some and then it was a battle to get the wood burning.
But I grew up burning dry wood and I learned from many neighbors who did not burn dry wood that there is a big difference between burning dry or green wood and all favors dry. But let's compare that year we burned green wood with what we have been burning the past several years. And fwiw, wood heat is our only heat source in winter; we have no back up furnace.
We purchased our first epa stove in 2007 so this makes our sixth year for heating with this stove. The wood we've burned in this stove has been probably 95-98% white ash. So it is good to compare with that winter when we burned green wood.
That winter with green wood I do not remember for certain how many cord we burned but will guess around 7-8 cord. We also closed off part of our house to try to stay reasonably warm. Since installing the new stove we have never had to close off any part of the house. The most wood we've burned during any one winter in this stove is 3 cord. The least was a bit under 2 cord and that was last winter which was an unusual winter.
We did some remodeling before last winter adding a lot of insulation, putting in new windows and doors and we also put on a small addition. Of course we do not know yet how much wood we'll burn this winter but we are guessing it won't be much over 2 cord. That is a whole lot less work than burning 7 cord! And remember, we no longer close off part of the house. In addition, we keep the temperature in our house 80+ degrees. I just looked at the thermometer and at present it is exactly 80 in here.
Now let's look at the chimney. That year we burned green wood we were constantly cleaning the chimney and always got lots of creosote from it and the cap. After installing our present stove, we cleaned the chimney after 2 years just to see what was in there. We got about a cup of soot from it. No creosote. So when we are done burning this spring the chimney will be 4 years since being cleaned. We might clean it this summer but will determine that later.
My whole point is that if you give your wood time to dry and dry it properly (don't count drying time until the wood has been split and stacked out in the wind to dry), you will burn a lot less wood to get the same amount of heat so that will save you money and labor. In addition, you won't have to clean the chimney as often nor will you be fighting the fire. I also believe your stove will last longer and for certain it seems the gaskets last much longer.
Until we can come up with a good way to burn water, it is just not a good practice to burn wood before it has dried to a decent level of moisture. That takes time. We usually give our wood 3 years or more in the stack before we burn it. The benefits are numerous and we are very thankful because it saves us much labor and dollars.
Now I'd best quit before I really get carried away.
Yes, young man, but you said it all. Water holds, the heat, correct? which is creosote, creosote sticks to stuff. as in the lava rocks, the heat transfers to the basalt lava rocks, and then they heat up and burn the creosote. I took a video yesterday of this. Yes, dry wood fires up faster, but like i was saying the fact that I have a solid layer of lava rocks above the fire, it trapping the heat inside the combustion chamber, burning the dryer wood up faster. I also burn tires, trash in my stove with no smoke, the lava rocks. I am going over to my mothers house to post this video that i took yesterday, you may find it interesting, or not. The choice is yours. I will post the video on youtube with the title being this thread. "Ahh you gotta love the locust" If there is no smoke then there can't be CREOSOTE.For starters I'm not sure how you think that waters latent heat capacity would benefit the system you describe. Water can only absorb heat reducing the transfer to the lava rock you believe is capturing heat and volatiles. Seems someone told you this fact but it has no relevance here except that it would be reduce efficiency of the burn.
If the system you describe has any real benefits it would function better with less water (dry wood). The fact that wet wood burns slower (and at a lower temp) is no mystery, it's wet. Better to burn dry wood and control your air.
The byproducts of complete combustion, there are only two. Co2 and h2o. I find that kind of odd, that a fire that is burning at optimum efficiency, it puts out water and carbon dioxide. Yes, Your right, I'm not going to throw a cup of water in everytime, that i throw in a hunk of wood. But, when you have a tree as in only locust, that is freshly cut down. water is just not oozin out of it. Locust starts to dry check itself within the first two days. I wood like for you toi watch the video that I made just for this, I want for you to see it. its on youtube, ibought this stove from a guy. under you gotta love the locust. With your fire, fire is put out by water, lets say there is a 100 year old two story house, ya know the one that is made out of true 2 by 4' and its on fire. I have a water hose from the next door neighbor house tryin to put it out, in reality I am just fueling it. Ok, then the fire department comes they more than likely will have 3 to four 3 inch lines and they will get it out, but it takes a whole hell of alot of water to make that happen. Its funny that you talked about, water putting out fire. When alex looks at water i see a fuel, oxygen combo. Hydrogen fuel cell cars, to put it bluntly, there will come a day that we put water in are cars to create in essesnce a fire to make them go. What 2 molecules make up water, 2 hydrogen atoms and a single oxygen atom. Hydrogen is a fuel and oxygen is a oxidizer, which reacts with hydrogen, or methane, butane, acetelyne and on and on..........Yes correct but it's not benefitting you. Waters high latent heat capacity (which you cited) means it absorbs heat (energy) without a concurrent rise in temperature. That means it is sapping energy from the system without providing anything useful. The water eventually boils once the latent heat capacity is overcome (after sucking up enough energy) which occurs at a very low temp relative to the type of heat you should achieve in a wood stove (500+) and then floats off up the stack. If you are equating creosote with water or believe that the lava rock is also retaining the water then you would have to run at very low temps but I doubt that that is the case even with wet wood.
To take advantage of waters high latent heat capacity water is heated in a closed system (like a boiler with baseboard heat). In your setup the water vapor goes out the stack at a low temp before you can get that heat back.
You may have a viable system but the point is if you could control the air better it necessarily must work better without excess water. Water after all is used to put out fires because it cools the fire and displaces O2.
My friend i can burn tires in my stoves, with the lava rock filter. Its on youtube. One day you will see, that this so called troll. Look up mcguire stoves on youtube, and you will feel like a schmuck, my friend. I have patience for people, who speak, what they know.... I am hear to spread the word about lava rocks, Just think and let yourr mind swell, with knowledge. do you realize that 600 years ago, we thought the world was SQUARE. Good day my friend!I has suspected it before but that post by our new friend Alex Johnson sort of spelled it out free and clear. Alex is a troll and only trying to stir up the clan. This thread does not deserve even one more post.
So go ahead Alex and burn your tires in your stove. Just tell it somewhere else.
I like to know how long it takes locust to dry so you can burn it with out worrying about creosote?
We got some cotton wood the first year we got our stove that was cut and stacked for 6 months then we split it. 3 weeks later it was good to go. So each wood is different.
Dennis, With much respect, I will leave and not come back. I am a open minded more than most, I know this. I live in the state of missouri, In Saint Joe, I have been working with the local university, actually Missouri Western State University. They have been taking Infrared Spectroscopy Samples. we have been capturing, flue gas samples. In the state of missouri, it is in violation to "The open burning of tires" but it states that you can burn tires in a apparatus that has a stack. I can guarantee you this there are people that do it, regularly. Im not one of them because they create way to much heat, specially when there is no smoke. I have had the lava rocks up to 2400F. What i found, while doing research for my project, there are few states that allow for one tire to be burnt in a stack configuration. I have found a away for this to be done smoke free, I achieved the complete combustion, with the aid of a 4inch thick lava rock filter to pass the particulates through. I truly apologize to all of you, if i have ruffled feathers. That was not my intentions, my intentions were wanting to talk to some people kinda like me. Black locust is my favorite wood, its a weed tree. I had a meeting with a local coal fired electrical producer, about my concepts. Did you know that every full load of coal in a single train car, over half will be wasted. sub critical power plant, 38% efficient, Super Critical 45%, Ultra Super critical 45.6% efficient, that's ridiculous gentleman. I still love Black Locust for heat, and hickory for smokin Respectfully Alex, peace be with you gentleman.Alex, I had not planned on posting to this thread any more but just wanted to warn you about one thing. You are posting that you burn tires in your stove. I can not tell you about where you live but will tell you that in most places, someone could turn you in and you would be facing a huge fine for burning those tires. How much? Last one I know of who was fined had to pay the State $10,000.00. So you might be well advised to stop with these posts lest you get yourself into some big time trouble.
