dondero14
I did take the andirons out I put longer logs east west on the bottom and shorter logs 16 inch under north south on top. You should be ok the logs won't roll and hit the glass. Do you have the reduction plate in? I usually get the stove to 1,300 or under.
No not yet. I need to get a hold of the store that I bought it from to have them order one. I did see this morning i'm getting some decent amount left burning in the back this morning. Got about 9 hours of burning last night. Cat temp said 350 but for some reason the blower had shutoff. Stove was still warm. Things are starting to get there.
n20intergra, do you have a contact number for your regency rep. I live not too far from Norton and would like to get a hold of a restrictor plate. That is my curiosity too with getting the fire heated up with the restrictor plate in. If you have anything less than semi seasoned wood i'm sure its gotta be pretty tough to get fired up and up to temp to close the bypass.
That's crazy right? We are new to this, so what do we know, but the cat wouldn't even work if I understand this right. We get probably a good 6 hours of heat, before we need to refuel. The heat is great, but like most others a little disappointing on the burn time. And I would love to talk to a regency tech, but cannot find a number, just a note that says there's a support line for the dealers. How did you guys get to talk to a Regency tech?![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/150/150405-8f1f06bee4cea7f00f48bd6a23735e02.jpg?hash=58BAI4WFRC)
