I would take a Jotul over a VC any day. You just can't trust VC to stand behind its stoves.
We have an Oslo now and its a good stove but not perfect by a long shot. It always makes it through the night, but just barely. That's the tradeoff for not having a cat. While its a lot less fussy to operate than, say, a VC Encore, it is not fool proof . Getting a fire going again takes a certain amount of finesse, and the ash tray requires cleaning every other day. This is not a simple job because, unless you do it when the fire is almost out, the stoves goes into a runaway combustion mode while the ash door is open, roaring and pulsating like a chimney fire. Worse, ashes falling in the back of the pit often block the box from going back into position, so the door can't be closed until the ashes are removed with an appropriate tool, which can be a quite intimidating job while the stove is in its runaway mode. Once you get used to it its pretty easy to deal with, but not a job for the timid or inexperienced.
It's also a relatively filthy stove to operate - you cannot open the front door without making a mess, and most Oslo owners take great pains not to.
But on the other hand, its a solid, simple device and should last a long time without needing service.
