Installing an Econoburn.
WoodChoppa
74
N.D.
Just got a shiny blue Econoburn and looking for assistance hooking her up. Let's start at the bottom. The boiler comes bolted to a pallet, is it okay to install as is or wiser to do away with the pallet and set her down? Guess no risk of the thing moving anywhere...right? My slab may not be exactly level but it's not too bad, is this a concern at all?
Thanks.
you'll get a full days burning out of the pallet . I leveled my boiler up wih a floor jack and just put steel spacers under the corners
Take the Econoburn off of the pallet. It will rock a bit being on the pallet, you will notice it when you load it. Shim it up with steel washers or what ever to make up for your floor being a bit off. If you don't know it there is a lifting hook built into the top of the boiler under the 12" access cover. Be carefull to not pinch the wires in there.
